Rpm?
Old Sep 10, 2001 | 09:26 PM
rx-7 inme's Avatar
Question Rpm?
Heres a quick question. Since the output shaft turns 3 times per 1 rotor rotation, Is the rpm gauge based on output revolutions or rotor revolutions? I'm just curious.
Also, on the stock temp gauge, where should the needle run? It seems that the car runs really hot. I haven't anything to compare it to, though I have watched the guage go up to about mid point and cycle down as if it is cooling. I did reciently replace the thermo.
Old Sep 10, 2001 | 11:33 PM
Pele's Avatar
Right near Malloy
RPM = E-shaft rev's.
Temp should go no more than halfway up. I'd get nervous at right of half and shutdown at three quarters.
Old Sep 11, 2001 | 02:43 AM
Jeff20B's Avatar
Lapping = Fapping
The rpm guage, or tachometer, measures two sparks per eccentric shaft rotation, the same as a 4 boinger. An aftermarket tach on a rotary needs to be set to 4 cylinder mode.
I wouldn't get worried untill the temp guage went over half.
dona1326cosprings7
Oct 29, 2015 06:47 AM
LongDuck
Oct 7, 2015 08:12 PM
eplusz
15
Oct 7, 2015 04:04 PM
Einheri
Oct 7, 2015 12:23 PM
musker
Oct 1, 2015 05:58 PM
