removing oil injectors on 3rd gen?
Old Jun 29, 2003 | 12:45 PM
93redFD's Avatar
removing the oil injectors on 3rd gen and using epoxy or something stronger to fill in holes? Lets just say I cant use bolts. I had to shortn a bolt and when I did I f**k the threads up and I put bolts in and thought I should take them out for teflon sealent and when I did , it cross threaded. Also When you put the bolts in aluminum shavings are all in the hole. I did bolts on my last motor and my engine builder said that it looks like I got a bunch of grit in my oil(possibly metal shavings?)
Old Jun 29, 2003 | 06:21 PM
Lost Time's Avatar
Chimera Driver
Why not just disable the OMP and cap-off the injectors? That way they fill the hole, but you'll eliminate their functionality.
FD7KiD
15
Feb 26, 2021 10:12 PM
sYnth.
Aug 19, 2015 06:27 PM
FD7KiD
Aug 17, 2015 11:50 PM
