I have NGK spark plugs.
I bought these for 2nd vert.
Can I use these for 3rd?
two of them says NGK 3559 BUR7EQ, and
two of them says NGK 3483 BUR9EQ.
Does somebody know where I can use or not...?
haha, its the same plug. . . the only difference is the 3rd gen is a platinum plug. same heat range and everything, just not platinum. you dont really even need platinum on these cars. . . they foul out so quickly anyways. haha.
paul
paul
Trending Topics
Originally posted by kyle@insight
Make sure to gap them correctly. I don't know if there is a difference between what the gap should be on an NA FC and an FD, but better safe than sorry.
I don't know if this is a joke or something, but you can't gap our spark plugs.
9s in the top (T is for trailing) and 7s in the lower holes (L is for leading).....is your 7 stock? If not, you're definitely not doing it any favors by running 7s leading. I run 10.5s leading and 11s trailing, but it's all dependant on mods
Originally posted by weaklink
My car's fairly modded and I run 7s/9s. Car idles and runs much smoother than with all 9s.
Originally posted by GoodfellaFD3S
what mods do you have, what boost are you running, etc. I've never seen a high hp auto, so I'm curious
chuckle...PM me when you get back. You're from around Dallas right? I'm only about 2.5 hours away from there. I haven't dyno'd the car, so I guess I shouldn't make any high hp claims. Anyway, I'd love to see your car, and I was thinking of taking mine to Gotham for tuning and to discuss some oil cooler upgrade stuff.
Prediict
32
Nov 18, 2015 08:41 AM
