where does the bov connect to?
Old Jun 27, 2003 | 08:20 AM
timmya2's Avatar
Question where does the bov connect to?
hi just wondering where exactly the bov connects to?
dya have to weld it in?
or fairly easy to install..
oh and 1 more.. (sorry its not about the subject) but does anyone have a pic or diagram where the speedo cable connects to the gauge cluster?
and in order for it to come off entirely.. is it just the speedo cable that needs to be detached? or are there other cables?
anyone got a complete write up or diagram.. rotaryrx7.com doesnt really explain it
sorry
and thanx heaps guy
Old Jun 27, 2003 | 10:51 AM
diabolical1's Avatar
unless you're using a turbo-to-throttle body pipe that has provisions for it, yes, BOV's have to welded on. actually, the little cup that they sit in (not sure what else to call it ) has to be welded in. the BOV itself will probably have a ring that holds it in the "cup-part".
on the speedo cable, it's been a while, but if i remember correctly, then it's just the one cable that leads from the tranny to the gauge cluster - no others have to be removed. however, the gauge side is a pain in the tush!
hope this helps ...
Old Jun 27, 2003 | 04:45 PM
REVHED's Avatar
Hunting Skylines
You don't even have a turbo so why are you asking about BOV's?
Old Jun 27, 2003 | 07:10 PM
timmya2's Avatar
revhead.. u in sydney?
Old Jun 28, 2003 | 12:03 AM
jutny's Avatar
SA all the Way!
the gauge cluster has three connections to it. There are 2 round bundles of wire that connect to it and on the left (looking at the back of the cluster) is the speedo connection. It's easy to get out, just a little plastic clip holds it into the gauge cluster. Personally, i have more problems getting the wire bundles back into the cluster with it in place (stupid way of keying the connector) than i do getting the speedo cable off.
oh goddamn you and your wrong side drive car ... now i cant help because i dont know if the sides are still the same.
Old Jun 28, 2003 | 12:44 AM
syklone's Avatar
now for sale
Old Jun 28, 2003 | 02:28 AM
REVHED's Avatar
Hunting Skylines
Brisbane.
If I seem to be taking the **** out of you it's because I'm desperately trying to point you in the right direction. Monster tacho's with auto gearboxes and fake BOV's simply don't belong on an Rx-7... or any other car for that matter.
Old Jun 28, 2003 | 03:36 AM
timmya2's Avatar
buwahaha give me a break
im changing it to manual
my only priority is to be different anyways
Old Jun 28, 2003 | 10:52 AM
... I'm desperately trying to point you in the right direction. Monster tacho's with auto gearboxes and fake BOV's simply don't belong on an Rx-7... or any other car for that matter.
this is just for show?
i originally thought you were someone planning a turbo project, but after watching this drama unfold ... i'm gonna have to second what Revhed said ...
there are several ways to be different that will compromise the integrity of neither your Rx-7's nor your reputations ... if you're honestly looking for ideas feel free to ask (you can even PM me if you wish - i may not answer quickly all the time, but as long as i log in to the board i WILL respond) - just don't travel the wrong path. i's hard to find your back ...
Old Jun 28, 2003 | 08:23 PM
timmya2's Avatar
yeh maybe true..
so hard to get a turbo for the 12a though..
Old Jun 29, 2003 | 01:01 AM
fatboy7's Avatar
Got Boost?
C'mon, don't install a BOV until the turbo goes in....
First of all, it will do absolutely nothing; no sound, no performance, because there is no positive pressure to bleed off. Secondly, It will make you look like a fool. Last but not least, where do you think you could install one.... you've got a 12A. The carb bonnet would be the only possible place, and when you do go turbo, you're garenteed to throw the bonnet in the trash.
Old Jun 29, 2003 | 01:04 AM
fatboy7's Avatar
Got Boost?
Oh, BTW, you don't have to go turbo if your pocket book won't allow. There are cheaper alternatives, perhaps not as powerful, but good none-the-less....
Old Jun 29, 2003 | 04:30 AM
timmya2's Avatar
like?
Old Jun 29, 2003 | 11:14 AM
fatboy7's Avatar
Got Boost?
Exhaust
Carb
Porting
4.444 gears
Nitrous
Ignition
Wieght reduction
etc.
Old Jun 29, 2003 | 03:40 PM
dude ~ just do yourself a favor. try to set a realistic power/performance goal, then do a search for ideas.
here's a start ... Ideas for 150 HP 12A
Old Jun 29, 2003 | 04:58 PM
Pele's Avatar
Right near Malloy
Flange... The word I think you're looking for is Flange.
Old Jun 29, 2003 | 05:45 PM
LOL flange ... ahhh, yeah, that works!
muchas gracias, pele
Sethix
Nov 3, 2017 11:48 PM
Captain Hook
13
Oct 4, 2015 06:35 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
