HELP... Coolant Leak!!!
Old Jun 9, 2003 | 12:35 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
I've got coolant leaking from the long bolt on the waterpump that secures the alternator bracket. I've torqued it to spec and dare not tighten it any more (had several other bolts break). I recently changed out the gasket but I didn't use any silicone or sealant on the treads, should I have? Thanks in advance.
Old Jun 9, 2003 | 02:35 PM
HDP's Avatar
HDP
HELP... ttt
Old Jun 9, 2003 | 10:46 PM
HDP's Avatar
HDP
Man, I can't believe no one has even bothered to help me out... all the "good" peeps must be on vacation.
Old Jun 9, 2003 | 11:56 PM
lovemyseven's Avatar
What funny smell?
I used a sealant called hylomar, it is blue, and I bought it at auto zone. you should put it all over the gasket that seals the water pump onto the motor as well as around the gasket on the thermostat
Old Jun 10, 2003 | 12:22 AM
FormerPorscheGuy's Avatar
Yes it is for sale.
Ya, you should use the blue stuff lovemyseven is talking about. It will seal it right up. The only problem is that you will need to pull the water pump and redo the seal. Have fun.
Old Jun 10, 2003 | 10:47 PM
swbrad's Avatar
I agree with lovemyseven too. Your gasket has failed and you will need to redo the whole job which is par for my course.
Old Jun 11, 2003 | 07:18 AM
HDP's Avatar
HDP
Which gasket(s) do I need to redo, the water pump gasket, water pump housing gasket or both? It was a bitch replacing the housing gasket.
Old Jun 11, 2003 | 08:48 AM
good luck
Old Jun 11, 2003 | 08:43 PM
SilverRX7's Avatar
If you are not leaking coolant when the bolt is done up, dont worry about it.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
