What Pre-Mix do you use?
Old Jun 3, 2003 | 10:10 PM
smnc's Avatar
EliteHardcoreCannuckSquad
Question What Pre-Mix do you use?
Well, the OMP on my 85 S model is pooched, so I'm down to using pre-mix.
My first choice is MMO, but they no longer sell it in Canada, so I'm looking for an alternative as so not to drain my limited supply.
So, what do you fine folks use for pre-mix?
Thanks!
Old Jun 3, 2003 | 10:43 PM
WackyRotary's Avatar
standard combustion
I use the cheapest crap from Walmart. Supertech outboard 2cycle oil. 1oz/gallon gas. Works GREAT. I have taken two engines apart after using it to find VERY clean rotors compared to OMP. Carbon doesn't stick very well with 2cycle oil and helps the seals keep moving freely better then engine oil.
Old Jun 3, 2003 | 10:55 PM
AdrenalifeRX7's Avatar
Are you gonna shift?!
This typical subject is usually limited to 2 major choices of premixes. Marvel Mystery Oil if it's available, 2 stroke oil if it is not (Canada). But that's just my opinion. I have used MMO for a while now and it works great. 16 oz of MMO per full tank.
Old Jun 3, 2003 | 11:21 PM
85gsl2ndtimearound's Avatar
you put afull 16oz. of mmo everytime you fill up?
Old Jun 3, 2003 | 11:33 PM
FuLLsMoKe's Avatar
"By the beard of Zeus!"
well, i put about 10-12 oz of mmo everytime i fill up...
Old Jun 3, 2003 | 11:46 PM
wwilliam54's Avatar
it WILL run
16oz of the walmart brand jetski 2 cycle
MMO is just too expensive for every tank
Old Jun 4, 2003 | 12:02 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
Castrol 2-stroke. Pleantiful to buy, long history of good products.
Old Jun 4, 2003 | 06:47 AM
inittab's Avatar
I read your email
I use the same stuff!
Old Jun 4, 2003 | 09:59 AM
standard combustion
I hear that! I thought about using AMSoil 2cycle but I already have to buy premium gasoline with my blowthrough 12a turbo. I don't want the cost of filling up to increase by another(10cents~oz amsoil) a gallon gas because of the oil I add. Really is expensive with spirited driving-14mpg.
Old Jun 4, 2003 | 11:18 AM
fatboy7's Avatar
Got Boost?
Well any oil that is designed to burn as it lubricates is probably a better dry seal lubricant then common 4 Stroke motor oil. Our engines may like 2 Stroke premix, but its not a 2 stroke. It doesn't rely on the premixed oil for cooling, and lubricating the whole engine, only several of the seals. The cooling is well covered by the water jackets and oil flow. Like WackyRotary said in his first post... they engines come out cleaner even with the cheap crap. Why spend a ton of money if it doesn't provide much if any benifit?
rotor_veux
Sep 3, 2015 07:10 PM
elegance
Jul 21, 2004 09:23 AM
1stgen_tn
Mar 14, 2004 02:44 PM
1987RX7guy
27
Apr 6, 2003 12:31 AM
Midnight Hour
Sep 14, 2002 02:05 PM
