Uh oh, oil cooler line busted...
Old May 22, 2003 | 12:53 AM
ejmack1's Avatar
Lawn Ornament
I just got her runnin and all the fluids filled completely, tooker her around the block... get it back in front of the house and the damn oil level buzzer comes on... I pull it in the drive way and shut it off. I lost about 2.5 quarts of oil through a damn busted oil cooler return line...
Besides having to replace the line is there any other problems that might have been caused by this happening?
Old May 22, 2003 | 12:56 AM
spurvo's Avatar
don't race, don't need to
Did you replace the O-rings in the engine side connector? It's on the inside of the big bolt like part of the connector. If you need some, call Pineapple Racing. They are the only source I know of, and you may not need to replace the entire line if it's just the O-ring.
I replaced mine, and it's about the only place my new engine ISN'T leaking
Old May 22, 2003 | 01:03 AM
ejmack1's Avatar
Lawn Ornament
you think the engine is ok though?
Old May 22, 2003 | 01:16 AM
spurvo's Avatar
if you ONLY lost 2.5 quarts and ran no more than a block, yer most likely ok. The combustion chambers are lubricated through the MOP, so low-ish oil doesn't starve that portion of the system of oil.
Your car is Satan.
Old May 22, 2003 | 01:22 AM
ejmack1's Avatar
Lawn Ornament
yeah it was leakin around the block but the oil level light didn't come on till i got right in front of my house...
Old May 22, 2003 | 08:08 AM
paw140's Avatar
I can tell you that the dealer doesn't sell only the o-rings. You have to buy the entire line!
Old May 22, 2003 | 08:20 AM
Railgun's Avatar
I won't let go
Veteran: Marine Corp
You should be ok. I blew my oil and coolant lines last summer after a quick hard drive. I didn't know at the time and had even revved the motor a bit more and had to shut it off immediately (it was a wreck). I haven't had any problems with the motor of turbos. Compression/vacuum is still good and boosting at about 12 psi with no issues. You'll be ok.
Old May 22, 2003 | 09:19 AM
Railgun's Avatar
I won't let go
Double
Old May 22, 2003 | 12:38 PM
spurvo's Avatar
that's right paw, which is why I mentioned Pineapple. They bought a large number of after market O-rings for exactly this reason. Pretty sure it's viton material.
I bought a few from them myself. No leaks
Old May 22, 2003 | 03:04 PM
93BlackFD's Avatar
built my own engine
if you blew the actual lines i'll sell you my old ones for cheap, i'm going aircraft
Old Aug 10, 2003 | 12:54 PM
potatochobit's Avatar
which orings doesnt the dealer sell? im going to be adding an R2 cooler and will be putting on all the lines.
FD7KiD
15
Feb 26, 2021 10:12 PM
FD7KiD
Aug 17, 2015 11:50 PM
