Surging under light load, whats the fix?
Old Sep 3, 2001 | 11:33 AM
setzep's Avatar
Like it says ^. Its a 12a stock everything. When your under light throttle or no throttle the thing surges, kicks and sputters, at wfo it runs great. Any ideas?? Could it be that shutter valve under the carb? I just want to get it running good so I can go try to trade the 12a and trans for a T2 trans at a local Rx-7 place.
Old Sep 3, 2001 | 12:01 PM
Pele's Avatar
Right near Malloy
Does your engine sound like a goose on crack?
Check the shutter valve pipe. (Pictured below) If it's sucking air at idle, it's bad.. Just shove something in the hose. The only price you pay is some small backfiring.
Old Sep 3, 2001 | 12:31 PM
setzep's Avatar
she's sucking air alright... But when I plug the line it runs shittier hmmm... Any other ideas??
Old Sep 3, 2001 | 04:13 PM
DONNA's Avatar
Plugging the pipe hose made mine run rougher too, but i adjusted the air/fuel mix till it settled at 750/800 rpms////still has some mild dead misses at times thou.....good luck,,,,,,
Old Sep 3, 2001 | 05:14 PM
setzep's Avatar
Thanks Donna I'll give her a try
Old Sep 4, 2001 | 01:49 AM
Felix Wankel's Avatar
Super Newbie
Check your fuel filter for rust :p
Old Sep 4, 2001 | 02:05 AM
red7's Avatar
Mine sucks air also but my iddle is fine at least 90% of the time. The other time it iddles low and rough, but either way is sucking air through the shutter valve.
Old Sep 4, 2001 | 02:58 AM
Super Newbie
Stop putting NOS in your air cleaner
Old Sep 4, 2001 | 12:15 PM
cpt_gloval's Avatar
KARATE EXPLOSION
Re: Does your engine sound like a goose on crack?
OOH! how the hell do you fix the shutter valve? mine's bad and i want to fix it.
see this thread: https://www.rx7club.com/vforums/show...threadid=18145
Old Sep 4, 2001 | 07:37 PM
Pele's Avatar
Right near Malloy
Make sure nobody tried to "compensate" for the bad shutter valve.
When I first got my 7, the idle was cranked all the way to nothing(Slacken the throttle cable and watch the engine die) , the throttle cable was tightened to bring it up to 1500 RPM to get over the sputteriness of the shutter valve, and several hoses and wire were disconnected and plugged where applicable. She didn't get miles per gallon... It was the other way around.
Everything was re-routed and put back properly when I got the carb rebuilt and everytihng was readjusted.
Old Sep 4, 2001 | 07:45 PM
Pele's Avatar
Right near Malloy
Re: Re: Does your engine sound like a goose on crack?
http://www.mazdatrix.com/c-5.htm
http://www.mazdatrix.com/faq/shutter.htm
13-120A-1480.....VALVE SHUTTER SHAFT...81-85 12A..............$ 24.87
13-1210-N201.....VALVE SHUTTER PLATE...81-85 BUTTERFLY........ $ 8.02
13-130A-1480.....VALVE SHUTTER.........81-85 12A RX7..........$ 63.00
13-139C-1480.....GASKET SHUTTER VALVE..VALVE TO MANIFOLD...... $ 1.20
Better off just leaving it plugged, but if you really wanna. Good luck
RPOdesign
Aug 27, 2015 11:42 PM
tsmith94FD
Aug 16, 2015 05:41 PM
ncds_fc
Aug 15, 2015 10:06 AM
rkhanso
Aug 13, 2015 11:40 AM
