cartech draw-through turbo
Old May 21, 2003 | 02:00 PM
buffalo's Avatar
Howzit--Came across a CarTech turbo kit for a 12a, was wondering what to expect with a draw-though setup, as far as pro's/con's, (highs'or headaches)- Aloha, Buff-P.S. It came with a Holly 4160/ 390cfm, seems kinda small?
Old Sep 21, 2003 | 10:47 AM
elnerdo's Avatar
are you interested in selling? i'm looking for a picture of one if nothing else
Old Sep 21, 2003 | 12:13 PM
RX794's Avatar
NYC's Loudest FD
Those Cartech blow through setups are awesome, those setups have seen 9sec passes before FD's were even out.
Old Sep 21, 2003 | 12:49 PM
Evil Aviator's Avatar
Rotorhead
The draw-through setup isn't all that great, but it will work fine if you just want a low budget turbo system producing low boost. You aren't going to set any speed records, but it will be a lot of fun zipping around town.
The draw-through is less expensive to build because it is simpler (no intercooler, no bypass valve), and the carb doesn't even know the engine is turbocharged so it doesn't require any special modifications. Expect carb icing problems, especially when the temperature gets below 50F. Also, cold starts may be a problem. Fortunately, you live in a hot environment.
Yes, that carb sounds a bit small. You may still want to try it out and see how it works. The CarTech kits were designed very well, and if that is the original carb, then it should work well.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
