Sponsored by: CARiD
1/2 bridge port & brake problems
Old May 11, 2003 | 09:37 AM
Erdin's Avatar
Water Injection Specialist
Hi there every one
Iv just got my car back and iv hed 1/2 bridge port with a single turbo but iam haveing problems with my brakes when the engine is just started when cold there seems to be no power in the braking system and once its warmed up it is beter but not as good as it was befor when engine was standed the other thing, it is hard to start up, is this normal for engines with 1/2 bridge ports or is there somthing wrong if so can some one help me.
Regards Erdin
Old May 12, 2003 | 05:04 PM
rotarygod's Avatar
Rotors still spinning
With a bridgeport you have much more port overlap than you did before. This will result in less vacuum in the engine at low rpms or cruising. Obviously under boost you don't have a vacuum either. For some of the more extreme porting styles a vacuum canister with a one way valve is used to help with this problem. Speaking of one way valves, did you somehow remove the factory one that is in line to the brake booster when the engine was out? This will give you problems as well.
Old May 12, 2003 | 08:15 PM
93 R1's Avatar
exactly what he said.
What are the specs on your setup?
Old May 12, 2003 | 09:32 PM
Erdin's Avatar
iam not sure if the one way valve has been removed ware can it be located so i can look.
Snoopy FD
Dec 8, 2015 01:45 PM
rx7brandon
Aug 16, 2015 10:55 AM
