can you really test plug wires witha multimeter?
Old Aug 31, 2001 | 11:42 AM
technonovice's Avatar
Jinx
I was told I could test the old spark plug wires that I removed with a common multimeter. I went to get one and then I was told that it really would not work reliably because there is not enough voltage. So I did not buy it.
After a wire and plug job, I noticed one of the plugs was fouled much more than the others. So I hope to test the old wires that are now removed.
Old Sep 1, 2001 | 04:44 AM
turbovr6's Avatar
Yes, that is how you test wires. I don't knw who you spoke to, but they had no clue what they were talking about. Voltage has nothing to do with it. What you are measuring is resistance. Every car manufacturer test for wires involves checking the resistance of each wire and comparing the readings to the specifications in the repair manual.
The1Sun
Mar 18, 2018 11:08 PM
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
Snoopy FD
Dec 8, 2015 01:45 PM
