how to torque the power steering pulley?
Old May 7, 2003 | 09:40 PM
puma's Avatar
canadian monster
ok guys, i don't have any special tool but i have an air impact gun.
what have you guys done to fic that pulley? any special advice?
thanks a lot
puma
Old May 7, 2003 | 09:53 PM
cewrx7r1's Avatar
Eye In The Sky
Air impact wrench, you answered your own question. But use low torque.
Otherwise you have to make your own pulley holder and use a box end or socket by hand.
Old May 7, 2003 | 09:58 PM
puma's Avatar
canadian monster
ok and any way to keep the pulley from turning while you torque?
Old May 7, 2003 | 10:19 PM
93BlackFD's Avatar
built my own engine
there are two holes in the pulley, make a pulley holder that hold these holes
then you can remove it
Old May 7, 2003 | 10:22 PM
xstacy7's Avatar
I love when things work
or you could use a strap wrench, or just tighten it with the belt on...either way you don't have to spend the money for the impact wrench if you don't have one and it's good enough to drive it to a shop that does...but that's just me
Old May 8, 2003 | 03:48 PM
silver93's Avatar
or....you can put the belt on, tighten down the idler, and then tighten the pulley. it'll hold it -
Old May 8, 2003 | 05:08 PM
HDP's Avatar
HDP
A Fistfull of Dollars!
I found by using 2 craftsman 4.5mm 1/4 drive sockets (one deep and one shallow) and a 1/4 drive adapter on a 3/8 ratchet you can get good leverage to torque the nut. Put the shallow socket w/ ratchet in one hole and the deep socket in the other and brace the ratchet againt it in the opposite turning direction of the torque wrench/driver.
LunchboxCritter
15
Jan 3, 2016 04:11 PM
LMBTG
Sep 2, 2015 07:01 PM
c0rpse
Aug 25, 2015 11:50 PM
