NRS Rotorsports ceramic seal test results
Old 12-16-07, 03:41 AM
  #376
'Tuna'
crispeed's Avatar
Sporty backs up his 197mph!!.
http://www.agracingvideo.com/videos/...sporty7.63.wmv
crispeed is offline
Old 12-18-07, 05:09 AM
  #377
'Tuna'
crispeed's Avatar
Originally Posted by Glassman
Congrats to the Mazsport team who yesterday lowered the mark even further to 8.10 @ 164mph in the St/289 class.
It just keeps getting better and better, way to go guys!
It's that triple E philosophy again
Elevate Every Expectation with NRS Ceramic Power Seals
Here's the video.
MR12A 8.10@164mph
http://s272.photobucket.com/albums/j...R12A810164.flv
crispeed is offline
Old 12-18-07, 11:17 AM
  #378
Back door, no babies...
Davin's Avatar
sven, remember i got your 1piece gray 3mm seals? well, rich and ihor over at IR performance are finally putting them in. i will let you know how everything turns out!
Davin is offline
Old 12-18-07, 11:34 AM
  #379
Glassman's Avatar
Good news Davin! I'll bet your excited to see this thing running. Any chance you want to upgrade to 2pc seals??? LOL
Glassman is offline
Old 12-18-07, 11:48 AM
  #380
Davin's Avatar
nah, i like the durability of a 1 piece. i am not sure what i will be doing with my motor yet, but wanted the expendability of maybe making big power down the road
Davin is offline
Old 12-18-07, 12:48 PM
  #381
'Tuna'
crispeed's Avatar
Yea someone found out that I was running low and bought them all
So has the still been re-fired up.
There are a lot of 1pc junkies out there.
crispeed is offline
Old 12-18-07, 06:52 PM
  #382
Living life 9 seconds at a time
ErnieT's Avatar
Sven,
Won't the 2 piece seal better than the one piece?
ErnieT is offline
Old 12-18-07, 07:13 PM
  #383
Glassman's Avatar
Originally Posted by ErnieT
Sven,
They should seal a lot better than 1pc
Issy from Select Maz in AU reported the highest cranking comp ever in over 25 years in the business with the NRS 2pc seals.
Regards, Sven
P.S. I talked to Ray so I think we are good to go when you are ready. You may want to organise with me which seals you want now as there will be a bit of a production slow down with some new developments and transition into the new material.
Glassman is offline
Old 12-19-07, 03:42 AM
  #384
CBR
CBR's Avatar
Hi Sven,what was the comp on cranking??
Brent
CBR is offline
Old 12-19-07, 10:01 AM
  #385
Glassman's Avatar
Brent
I believe Issy told me it was in the 140+ psi on 3mm 2pc
Glassman is offline
Old 12-19-07, 09:24 PM
  #386
In the burnout box...
mono4lamar's Avatar
140psi on 3mm seals Whoa!
mono4lamar is offline
Old 12-20-07, 10:28 AM
  #387
Glassman's Avatar
Yea that's what Issy reported. The wedge design was slightly different but sealing should be close to the same.
Glassman is offline
Old 12-20-07, 11:19 AM
  #388
FEED me
TRISPEEDFD3S's Avatar
So how much more efficient has the seals gotten since I've last inquired about them Sven? I know they were bad *** before, but after months of more work, how much more do you personally feel they have improved? I've been hurting in the pocket since some unfortunate things have happened, that I've had to pay for, but can you please PM me for a price list of your stuff. I think I'd hop onto the 3mm seals and your upgraded springs. Seems like they have no problem sealing whatsoever!
-Jeff
TRISPEEDFD3S is offline
Old 12-20-07, 11:51 AM
  #389
Glassman's Avatar
Well the biggest improvement would have to be the micro finishing. The quality of the entire surface is improved with this processing. We have applied this to the springs as well.
The next major improvement will be the new material. There is no like material that even comes close in strength, not even the material we use now. It is by far the best there is.
Glassman is offline
Old 12-21-07, 11:45 AM
  #390
Glassman's Avatar
Originally Posted by t-von
Is this new material more suited for extreme rotary's ( drag ect )? Can you speculate on the % of price increase with the new material? All these advancements in rotary tech really makes my day.
The new material will offer all the benefits the current material gives only better. It is substantially stronger and second to none.
My goal is to (if possible) keep the pricing the same and simply move everyone into a superior product.
Glassman is offline
Old 12-21-07, 06:19 PM
  #391
eccentric shafter
rotary8's Avatar
what kind of boost can we run on these new seals .
rotary8 is offline
Old 12-21-07, 06:27 PM
  #392
Just installed a set of the 3mm 1 piece greys in a customer's (davin's) motor. While the extra clearancing definitely took a little bit more time, you really can feel how much lighter than stock the seals are. Also, the springs are much beefier than the factory pieces
GoodfellaFD3S is offline
Old 12-21-07, 06:45 PM
  #393
Glassman's Avatar
Don't know, we haven't tried them yet but there is no reason they can't handle what the current seals can handle and then some. If your tune and build are good I don't know that there is a limit on boost you can run.
Sporty runs 40psi and some others run 45+psi. Enzo is going to run 50psi but he wants to do it on 2pc seals.
Glassman is offline
Old 12-21-07, 07:12 PM
  #394
eccentric shafter
rotary8's Avatar
we were running 30+ lbs on the stock mazda seals which do you like the best the 3mm single or two piece.
rotary8 is offline
Old 12-21-07, 07:31 PM
  #395
Rotor Head Extreme
t-von's Avatar
Damn sounds like these newer seals my infact find the actual limits of the rotary engine. I'm trying to speculate as to what may start to consistantly fail with-in the engine in the 60+ boost range.
t-von is offline
Old 12-21-07, 08:16 PM
  #396
Glassman's Avatar
For now I'm still recommending 1pc for those boost levels, they are pretty much all that I've been selling for the last few years so that's what we know works. 2pc testing will begin soon in all applications from street, road and drag. The only one who hasn't got their 2pc for testing is Gaby but that's because I will have some other ceramic goodies for him and we're going to send them all at once.
Glassman is offline
Old 12-22-07, 12:35 PM
  #397
Trionic's Avatar
Glassman, would you be willing to post some material specifications?
Specifically, black vs old gray vs new gray? The new gray is better in what way?
Hardness, toughness, stress/strain, yield strength, fracture, elastic limit, etc...? I'm not sure which measurement standards are most typical in the ceremet world but it would be great to see some hard numbers, if for no other reason than to compare the differences between your products.
I'm new here too though, maybe some technical materials information is posted someplace and I've missed it? I've read a bunch of anecdotal evidence but am having a hard time finding anything empirical.
Trionic is offline
Old 12-22-07, 09:29 PM
  #398
Glassman's Avatar
Yea it's on pg 2.
Black seals NLA and the new material fracture toughness is 11 MPa
Glassman is offline
Old 12-22-07, 09:48 PM
  #399
Trionic's Avatar
Very cool, thank you. Sending a PM to you when I reach 15 with this post.
Trionic is offline
Old 12-26-07, 08:31 PM
  #400
"Elusive, not deceptive!”
Barry Bordes's Avatar
Sven, please work on the 2mm springs.
I guess the only game in town for now is for 3mm seals. Who does a good job grinding the rotors to 3mm?
Barry
Barry Bordes is offline
Quick Reply: NRS Rotorsports ceramic seal test results
