Did I pop off a boost hose?
Old Aug 29, 2001 | 01:08 PM
mattfox38's Avatar
My car was running 10-8-10. Then it was in the shop forever. Last night it seemed slower so I did the 40-70 mph test, not timing just watching the boost gauge. I did a 9-5-7, also there is a loud "ffffffff" noise near the passenger side floor. It seems louder than normal, but the car has been gone so long I don't remember for sure. Thanks for the help. Oh, and if a hose is off how in the world would I find it? I'm not a mechanic so......
I do have silicon hoses and ties, but I don't know what else it could be.
Old Aug 29, 2001 | 02:50 PM
KZ1's Avatar
KZ1
check out steve cirrani's site, Lighting world of thunder, for the boost troubleshooting procedures.
coud be primary bost leak (3" hoses)
or just about everything else in there. good luck, let us know the results of some tests so we can help you out better.
Old Aug 29, 2001 | 03:30 PM
Toadman's Avatar
Nomad Mod
5 bucks its the y-pipe rubber coupler above the turbo inlet if it's a *whoosh* noise. Take off the plastic intake tubes and remove the rubber coupler. It's about the diameter of a coffee cup and secured by straps. It may not look damaged, but bend it around and look for cracks for vacuum to escape. These go out all the time. Any other boost leak will either make little noise or a high whistle usually. About 15 bucks to replace the coupler.
P/N N3A2-13-247, sugg retail 38.40.
Old Aug 29, 2001 | 04:53 PM
weaklink's Avatar
Resident Retard
why was the car in the shop? if they did any turbo work they may not have replaced the restrictor pills.
Old Aug 30, 2001 | 01:57 PM
mattfox38's Avatar
The car was in the shop for a new hood and the air conditioning was broken. Thanks for the input guys. What's the address to the Lightning in a world of thunders site. Thanks,
matt
Old Aug 30, 2001 | 05:52 PM
weaklink's Avatar
Resident Retard
http://www.scuderiaciriani.com/rx7/
rgordon1979
40
Mar 15, 2022 12:04 PM
NotMrButts
23
Sep 15, 2015 09:46 PM
Tem120
Sep 7, 2015 09:53 AM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
