I checked my compression today...
Old Apr 29, 2003 | 12:05 AM
Terrh's Avatar
STUCK. I got SNOWNED!!!!!
Question I checked my compression today...
110 PSI front rotor
109 PSI rear rotor
Are these numbers OK for a s5 turbo block?
What's spec? I have NO idea.
Also, the person on the inside of the car forgot to hold the throttle at WOT, would that throw things off?
Old Apr 29, 2003 | 12:07 AM
Bebesito21's Avatar
120 is new from stock. Make sure the engine was warmed up properly before hand. and the throttle has to be at WOT.
Old Apr 29, 2003 | 01:50 AM
hypntyz7's Avatar
The test will only be totally accurate if perofrmed on a warmed up engine, and with the throttle at WOT.
New spec is about 120-125.
VGC is 110-120
Good is 100-110
Getting weak is 90-100
Poor condition is under 90.
Old Apr 29, 2003 | 02:08 AM
rotary>piston's Avatar
at 1 mile high subtract about 20 psi from all of those numbers.
Damn, I wish I lived at sea level
Old Apr 29, 2003 | 10:49 AM
Terrh's Avatar
so my engine is fine then? Good.
What's up with the dubs on the pickup? Please tell me you didn't spend money on those.
Old Apr 29, 2003 | 11:57 AM
Cory Simpson's Avatar
I wanta be with the BUC!
Old Apr 29, 2003 | 02:03 PM
gr0undz3r0's Avatar
dont mess with him about those rims... he loves em. Kevin is a pro blinger...
Old Apr 29, 2003 | 02:15 PM
Cwaters's Avatar
Just Messing About
Don't forget that the compression difference between the two rotors (and also between faces??) has a spec.
Cold medicine has me all messed up and I can't rmember what the allowable difference is...
Old Apr 29, 2003 | 04:10 PM
I think it's 21 psi, or something
Old Apr 29, 2003 | 06:04 PM
TonyTurboII's Avatar
Glock Lover
I wondered too. I mean, I could see if it was lowered, and 2WD, but with the 4WD off-road package?
ZacMan
Sep 19, 2015 09:20 PM
BLK 93
11
Sep 9, 2015 10:56 AM
whinin
Sep 5, 2015 11:52 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
