Do I need new gaskets to install my Downpipe
Old Apr 27, 2003 | 11:36 PM
crai6m4ck's Avatar
Just purchased an M2 3" SS Downpipe from a guy on this forum... this Downpipe is brand new and never installed but I never received the gaskets for it. I just had my motor streetported less than 10,000 miles ago with all new seals and gaskets. I am under the assumption that the downpipe gasket should and would have been changed then. If it was do I really need to order a new gasket set or will I be just fine using the fairly new ones?
Old Apr 27, 2003 | 11:40 PM
CowsniperRX7's Avatar
Rear Admiral
I would get the new gasget. Gasgets are ment to crush once for a good seal. Your existing gasget has allready been crushed. Also, since it is a new DP it will probably seal differently than the stock pre-cat.
You could probably use the existing one, but I would'nt.
Old Apr 27, 2003 | 11:44 PM
crai6m4ck's Avatar
Can I just get a stock gasket or do I have to get a special one to fit the M2 3"?
Old Apr 27, 2003 | 11:45 PM
Rear Admiral
Stock should work I think. I'm not sure about the M2s though.
Old Apr 28, 2003 | 02:18 AM
Marshall's Avatar
The gasket on the turbo outlet to downpipe is like a $50 piece but can usually be reused. The downpipe to main cat/midpipe gasket should probably be replaced ($7 piece)
FD7KiD
15
Feb 26, 2021 10:12 PM
rotor_veux
Aug 31, 2015 07:49 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
