Carb problems
Old Apr 22, 2003 | 01:13 PM
R.P.M.'s Avatar
Likes to swear....alot
Angry Carb problems
Ok my FB has a pretty wicked stutter in first gear, but second gear revs right up to 7k fine, then third gear starts stuttering at about 5k. I can only get it going 160kms/hr.
I stripped off the rats nest and I think I plugged up all the vacume lines, but I'm not sure.
Anyone help me out.
Old Apr 22, 2003 | 01:16 PM
When you do that, there is one hose you're not supposed to block. And that may be your problem!
Old Apr 22, 2003 | 01:58 PM
R.P.M.'s Avatar
Well which one is it ???????
Old Apr 22, 2003 | 02:08 PM
slag's Avatar
I believe the hose he is referring to is the carb float bowl vent or carb vent hose as it's typically called.
If this works, click here
or here:
Its the fitting number 8 that should be either left open or vented to the air horn.
Old Apr 22, 2003 | 03:41 PM
poweRX-7's Avatar
hey slag,
just curious as to what the red circles are showing.
jeff
Old Apr 22, 2003 | 04:33 PM
Rx7carl's Avatar
Airflow is my life
No, hose 8 is for crankcase vent. The solenoid next to it is the vent solenoid for the carb, the actual vent is the triangle piece you see lookin down the carb.
The red circles are for the choke delay bellows.
rocket, you may have accidentally blocked your shutter valve. Did you use our tutorial on emissions removal?
Old Apr 22, 2003 | 05:29 PM
slag's Avatar
Thanks Carl for the clarification.
Are the choke delay fittings needed for choke operation? I yanked mine and capped them with vacuum fittings.
Joe
Old Apr 22, 2003 | 06:26 PM
Rx7carl's Avatar
Airflow is my life
No they are not needed, you can yank the whole thing, heater and all, but youll need to wire the choke to the actuating lever to have a working choke. (Kinda like the mech secondaries).
Old Apr 22, 2003 | 09:02 PM
slag's Avatar
Let me clarify. My choke does not stay out when pulled. I removed those tubes and plugged the holes. I have checked the magnet and also the choke switch and both spec out ok.
I am in the process of replacing the entire wiring harness in my car and when I get it back in place, I hope the choke works.
Old Apr 22, 2003 | 10:07 PM
vipernicus42's Avatar
Rotoholic Moderookie
Hey Guys,
My carb's being rebuilt, rather slowly, right now, and I made the biggest newberror of my life when I took it out. It was last summer, and I didn't label any of the tubes!!
So I was wondering, to the two or three of you who know about this (Slag, rx7Carl - author of the famous ratsnest removal) when I get the carb in, can I take some pics, e-mail you guys or post a thread for "let's match the hoses"?
I'd be FOREVER greatful. Right now when the names "solonoid" and "shutter valve" are thrown around, I can't make heads or tails of what's what on the carb... :S Man I wanna learn more.
Jon
Old Apr 23, 2003 | 11:32 AM
R.P.M.'s Avatar
I didn't know that there was a tutorial.
I'm with vipernicus42, I don't have a clue what you guys are talking about when you say "shutter valve" and stuff like that.
Could you show me a pic of where it is and what to block off.
Old Apr 23, 2003 | 11:35 AM
R.P.M.'s Avatar
Oh yeah and does that port between 6 and 7 with the gear clamp on it have to be blocked, cause mines not.
Old Apr 23, 2003 | 06:06 PM
Rx7carl's Avatar
Airflow is my life
slag, you probably have the choke relay off if the switch on the water pump is ok.
viper feel free to email me the pics, Im sorry but Im kinda busy but if I have time Ill snap some of a carb and reply to you. DC871@aol.com
heres the emissions removal tutorial link
http://maz_tutorials.totalimmage.com/
Old Apr 23, 2003 | 06:07 PM
Rx7carl's Avatar
Airflow is my life
Yes, look in the tutorial, all questions will be answered hopefully. If not feel free to email or ask here, but Im not on here all that much.
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
