how to connect ...?
Old Mar 14, 2003 | 10:17 AM
Crusader_9x's Avatar
how to connect ...?
hey all i got an after market koyo radiator for my 89 tII and was wondering how would i go about puting an electric fan onto it? it is a gm fan i am pretty sure it is he fiero fan. the fan is like an inch or two less in width on both sides compared to the radiator. so any ideas woudl be greatly appreciated
Old Mar 14, 2003 | 10:34 AM
Rotarded's Avatar
"Challenged" since 1993
Try zip ties through the fins. Just don't try and pull them really tight.
Old Mar 14, 2003 | 12:01 PM
HeffBoost's Avatar
Keep Right Except to Pass
Make a frame out of alum. angle?
Old Mar 14, 2003 | 08:10 PM
yah i thought abpout geting a couple pieces of metal/aluminum and bending them from the stock mounts to the efan but wanted other ideas to see if there would be a better one out there.
Old Mar 14, 2003 | 08:13 PM
Amur_'s Avatar
Refined Valley Dude
Originally posted by 'Vert in Vegas
My install was simple.
I didn't want to fasten the fan to the radiator core. (In my mind that is high risk for a radiator failure - but a lot of people have done it)
I made a frame out of 3/4" aluminum (90 degree bend) material. I bolted that to the exixting fan shroud mounts, with a layer of foam insulation between the aluminum the radiator. The fan bolts to the frame easily.
The wiring is real simple. Buy a thermostatic fan relay from Autozone for about $20 bucks. It is only a 4 wire hookup.
Old Mar 14, 2003 | 10:21 PM
thanks for the info
Sethix
Nov 3, 2017 11:48 PM
Captain Hook
13
Oct 4, 2015 06:35 PM
jim_chung
1st Gen General Discussion
Oct 4, 2015 09:09 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
nycgps
30
Sep 29, 2015 12:02 AM
