Block off plates for air pump pipes?
Old Mar 14, 2003 | 02:32 AM
JSpecRZ's Avatar
NA2 Pilot
Anyone know where I can get block off plates for the airpump pipes... there are 2 on the LIM...
TIA
Old Mar 14, 2003 | 03:15 AM
RX7Elmo's Avatar
i just went and got rubber caps and covered them. But if you want real block off plates, i think rx7store has them, or you can simply make your own.
Old Mar 14, 2003 | 03:52 AM
duboisr's Avatar
My mechanic makes them ,as needed just find someone to help you if you do not have the tools . good luck
Old Mar 14, 2003 | 01:18 PM
JSpecRZ's Avatar
NA2 Pilot
yeah... i think Jason only sells the kit...
Old Mar 14, 2003 | 01:49 PM
RX794's Avatar
NYC's Loudest FD
How about welding the holes shut, it's guaranteed NEVER to leak or allow any blowby, like block off plates will eventually.
Old Mar 14, 2003 | 02:34 PM
JONSKI's Avatar
5yr member, joined 2001
Why not just block-off your ACV and unplug/eliminate your airpump?
Why do you want to block off those pipes, anyway?
Old Mar 14, 2003 | 03:01 PM
JSpecRZ's Avatar
NA2 Pilot
my airpump is out... plus I eliminated the ACV, AWS(2) and EGR.
I want to take the pipes out to clean it up a bit, I had the pipes blocked off before.. but I just want them out..
I also need to order the DT block off also but don't know where to order these block offs. I tried to call and email K2RD but no response... I also tried going to Home Depot to find some aluminum sheets but they where too thin...
btw... what is ISC/BAC? there is a BOP for it...
Old Mar 14, 2003 | 03:21 PM
Marshall's Avatar
Sh*t I thought the ACV blockoff got rid of the pipes! What does this ACV plate blockoff exactly?
Old Mar 14, 2003 | 03:48 PM
JSpecRZ's Avatar
NA2 Pilot
The ACV has one pipe that goes to the airpump... but there is another one going from the airpump to the LIM... then another pipe from the LIM to the Main Cat....
The block off allows you to remove the actual ACV which is located under the UIM....
Old Mar 14, 2003 | 03:58 PM
yzf-r1's Avatar
look up past threads by spyfish in the "parts for sale" section
Old Mar 14, 2003 | 05:32 PM
Scrapiron7's Avatar
STi Boxer power!
Hmm so there are 3 pipes to plug when you remove the airpump, not 2? I plugged the one going to the Intake System, then the metal pipe near the intake pipe. Did I miss something??
Old Mar 14, 2003 | 07:02 PM
Scrapiron7's Avatar
STi Boxer power!
Do I need to block off the pipe coming out of the ACV if I have my airpump removed? Anyone?
Old Mar 14, 2003 | 07:11 PM
JONSKI's Avatar
ISC = Idle Speed Controller
BAC = Breath Alcohol Content?
Maybe someone else knows this one.
All of those pipes and the EGR connect to the ACV. Blocking off the ACV effectively blocks off all of those pipes and the EGR. The explanation of the ACV begins on page F-115 of the FSM (Factory Service Manual).
Old Mar 15, 2003 | 12:14 AM
JSpecRZ's Avatar
NA2 Pilot
Ahh.. yeah.. dunno what BAC is... thanks for the pic...
But what do you mean when you say, if you block off the ACV.. it eliminates the EGR too? Aren't they 2 different things? I alreay have my ACV and EGR blocked off...
Old Mar 15, 2003 | 01:19 PM
JONSKI's Avatar
Sorry, I read the FSM wrong. The EGR is not connected to the ACV in any way.
Old Jun 1, 2003 | 07:19 PM
Zoomspeed's Avatar
Thread be REBORN! MWHAHAHA
hey guys, need some help removing the hard pipes thta went to my airpump. The ones that sit between the intone manifold and the turbo y-pipe.
Well I'm trying to het these hard pipes out, and I tihnk I'm down to one more nut, then one that holds one of the pipes to the pasenger side of the intake manifold, but I can't get to it. I dont' have enough clearence aorund the nut to get a socket or a wrench on there. One of the pipes themselves is in the way. How do I get this off?
Old Jun 1, 2003 | 10:53 PM
JONSKI's Avatar
Those pipes come off?!
Old Jun 1, 2003 | 11:29 PM
Zoomspeed's Avatar
yeah it looks liek it, one bolt onhte y pipe, right next to the CRV, then on then 2 nuts on the passenger side of the intake manifold. Isn't that where you stick one of the BOPs?
Old Jun 2, 2003 | 02:47 PM
Zoomspeed's Avatar
bump
Old Jun 2, 2003 | 03:59 PM
JSpecRZ's Avatar
NA2 Pilot
are you talking about the pipe that goes behind the LIM? there are 2 10mm bolts behind there and pretty easy to get to...
Old Jun 2, 2003 | 11:28 PM
Zoomspeed's Avatar
no thats the one that faces the fire wall right?
I'm referring the one 90 degrees from that one which faces the passanger side of the engine bay. The nut I'm tring to get to is completely out of site. And it has almost no clearence around if for me to get any tool on.
Old Jun 3, 2003 | 05:36 AM
Cihuuy's Avatar
hmmm... i think i know which one your talking about... because i ponder myself on how to get it off... its the black tube isnt it sitting on top of the turbo right??
well the only way i could get if off is to remove the intake elbow from underneath the car and then you can take the black tube out. If not it wont go out all the way and it will be left hanging there...
Old Jun 3, 2003 | 11:17 AM
spyfish007's Avatar
Yellow Dragon is no more
The two holes in the LIM go to the ACV which is blocked off, so I never considered it important to block them off. That is the reason they are not in the kit. I have sold over 100 kits and no one has ever complained about any problems. Some people do want the additional plates just to clean things up a bit.
Old Jun 4, 2003 | 12:24 PM
Herblenny's Avatar
DGRR 2017 4/26-4/30, 2017
Spyfish007,
Are you still selling these kits.. if so, what does it come with.. I guess I could do the search..
Snoopy FD
Dec 8, 2015 01:45 PM
12abridgeport
Aug 17, 2015 06:28 PM
