Adding low impedance 720 cc injectors.
Old Aug 19, 2001 | 03:50 PM
13BAce's Avatar
On a long vacation
I gave my friend a set of ND 720's which I tested at 2.1 ohms. He had them put into his 90 TII, and the shop said he didn't need resistors, but I know the stock injectors are around 13 ohms. My friend is using a stock ECU with an F-CON. He says the car runs ok, but I think the injectors will burn out. Am I right?
Old Aug 19, 2001 | 04:19 PM
skibum9199's Avatar
college student
I would think it would harm the ecu first, but its possible that the injectors could fry ~ definetly put in the resistors, its not going to make the car run any worse, maybe better.. I had fried resistors and found someone on this forum w/ extras, picked them up for $25... (thanks!) So, that's what i'd recomend
~Jesse
Old Aug 19, 2001 | 04:53 PM
13BAce's Avatar
On a long vacation
~Jesse
Thanks. I'll let him know.
Old Aug 19, 2001 | 06:47 PM
fc3s.org's Avatar
OG
You can get the resistors from Radio Shack for a couple of bucks a piece. You just wire them inline with the injector.
Old Aug 19, 2001 | 08:53 PM
13BAce's Avatar
On a long vacation
Yeah, I know. I was just wondering why the shop would insist they're not needed.
Old Aug 19, 2001 | 10:16 PM
fc3s.org's Avatar
OG
Does the shop usually work on RX-7's? Sounds a bit weird for them to recommend against something that will save a future repair. Maybe they are trying to get repeat business(IE when either the injectors or the ECU go out)?
Old Aug 20, 2001 | 06:45 AM
13BAce's Avatar
On a long vacation
Yeah, they work on alot of RX-7's. It's Rampage in NY. I don't know if maybe the F-CON allows for low impedance injectors.
Old Sep 23, 2001 | 03:16 PM
HAILERS's Avatar
HAILERS
Little late for this, but http://www.k2rd.com/FC3S/MODS/FUEL/inj.htm
Old Sep 23, 2001 | 06:21 PM
13BAce's Avatar
On a long vacation
I've already seen that, but thanks anyway.
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
jeremyferguson4444
Sep 19, 2015 01:27 PM
