Flames out of tailpipe!!??
Old Aug 18, 2001 | 01:02 AM
FCrx7's Avatar
I've been told by other drivers when I race em that i shoot flames outta my tailpipes. They think its pretty awsome and that my car is fast as hell. The car is really fast I'm just not so sure this is a good thing. Should my car be shoot flames. Is this bad or good or doesnt it really matter and what would cause it to shoot flames.
Old Aug 18, 2001 | 01:49 AM
rx7_ragtop's Avatar
From: Ft. Worth, Texas, USA, Earth, Solar System...
Re: Flames out of tailpipe!!??
Hmmmm... from a performance standpoint, neither bad nor good.
From a coolness standpoint, good.
From a "don't look at me, I ain't doin' nuthin', honest officer!" standpoint, it's bad.
It's caused by a rich condition when you shift- throttle closes, less air goes into engine, but excess fuel is injected. No catalytic converter, so it goes all the way out the back and ignites when there is more air.
Brad
Old Aug 18, 2001 | 12:24 PM
Supermac's Avatar
It's pretty typical of rotaires without cats, Flame on Bro
Old Aug 18, 2001 | 12:35 PM
FCrx7's Avatar
Hey thanks for the feedback guys. Another question is running rich bad for the engine? should i get a fuel controller or upgrade the ECU?
Old Aug 18, 2001 | 03:24 PM
I think all you need is a good fuel pump
Old Aug 18, 2001 | 06:00 PM
skibum9199's Avatar
college student
I can't speak for other na's, but the ones i've driven(with full cats) tend to make this noise shifting at high rpm's.. From what i can gather, this is those flames, but since we have cats there is just a hard burst of hot exhaust, it sounds like a small explosion, like "fooof!" lasts like half a second, then does it every time ya redline it and shift... well, i was messing around with that plunger on the back of the TB that slows down the deacceleration( i forgot its name for the time being) . On my car and my friends, neither where really adjusted far enough in, ie the plunger didn't get pushed in very far by the tab that hits it. I adjusted mine and found that the sound went away, which means that the rich condidtion was probably at least lessoned, and the car also deaccels much smoother now. I set it so that the plunger goes almost all the way in when the throttle is closed.
What do you guys think?
~Jesse
Old Aug 18, 2001 | 08:01 PM
CanadianRX7's Avatar
yea its not even only when shifting at high rpm's just rev is up to 5 or 6 grand and take your foot of the gas and it will also do them
well it makes the popping noise but not 100% about the flames
i wish it always did the flames when it makes the pop noise but it doesnt always oh well
ps it doesnt mean your car is running rich either it just means u have no cats. it could be running rich also but it might not be.
FLAMES RULE only bad thing is that u have to pollish the carbon on your tips all the time
Old Aug 18, 2001 | 11:23 PM
Ryan "RX-7" Radio's Avatar
Dont forget guys that the rotary motors exaust is anywhere from 600 to 900 degrees hotter at the headers than a normal car. Without cats, you will most likely flame Ive seen some mamoth ones come out of my car! (3.5" in/4.5" out Muffler)
FLAME ON!
Old Aug 19, 2001 | 01:05 AM
Mykl's Avatar
FLAME ON!
600 to 900 degrees hotter? Are you sure? That seems a bit excessive to me.
Old Aug 19, 2001 | 02:03 AM
charger-'s Avatar
Yea I agree.... those figures sound a bit high...
Old Aug 19, 2001 | 02:15 AM
rxspeed87's Avatar
should I be able to spit flames out my *** when I get the header and presilencer on even though I have stock muffs
also if you take the TPS off your car thinks it is always wide open throttle. run rich as hell and prolly spit some big *** flames
Monsterbox
Jul 29, 2022 10:48 PM
joel(PA)
Oct 4, 2015 06:07 PM
JIMMY54
Aug 12, 2015 05:40 PM
cpt_gloval
Sep 28, 2001 04:15 PM
