Rough Idle When Hot
Old Aug 14, 2001 | 11:25 PM
neevosh's Avatar
The Dude Abides
Rough Idle When Hot
After my car is warmed up, and I shut it off, when I start it again(like after going to the store or getting gas), it doesn't want to idle. If I give it a little throttle and let off it almost dies out(and sometimes does). After driving it for a little bit it idles fine. Is there any way to fix this?
Old Aug 15, 2001 | 08:50 PM
Viper jr's Avatar
never mind - didn't thoroughly read your question
sorry, i have no help
Old Aug 16, 2001 | 12:26 PM
bploz RX7's Avatar
I have this same problem from time to time... just heat soak?? did you do the fan mod to keep them running after turning off the car??
Old Aug 16, 2001 | 05:03 PM
neevosh's Avatar
The Dude Abides
Yeah, I've done the fan mod. My temps don't go over 90C and I run the fans after I shut the car off and turn the heater to full blast to get some heat out.
Old Aug 18, 2001 | 12:13 AM
Nathan Kwok's Avatar
I have this almost the exact same problem and its at Mazdatrix right now getting looked at (and getting lots of goodies put in). Mine will drive ok, but it just won't idle right after heak soaking. It clears up after driving a bit though. John (the mechanic) said its probably an air control valve (can't remember details) sticking. I will post when its all fixed.
Old Aug 18, 2001 | 09:26 AM
Hyperite's Avatar
Vagina Junction
Thermowax rod, baby, thermowax.
~Tom
Old Aug 18, 2001 | 02:58 PM
djantlive's Avatar
What's thermo wax? And where is the air control valve? How can I inspect or clean it?
Mine does it once in a while. I don't think RX7 likes the hot temp to begine with. I think a small vac leak can also be the cause to bad idle.
Old Jul 19, 2003 | 03:36 AM
4Fun's Avatar
Dont make me Laugh
Anyone get this cleared up?
Old Jul 19, 2003 | 03:40 AM
Recipe7's Avatar
With Life.
ive got the same problem, i could also use a solution besides going to the mechanic
Old Jul 19, 2003 | 09:22 AM
Meiogirl's Avatar
the REAL deal
harhar i am yet another person with this problem. i figured it was something along the lines of what he said^^^
Old Jul 19, 2003 | 12:54 PM
sicminded's Avatar
same problem here.
will be brining the car to the shop (ricksrotary at pleasanton,ca) to get a 30k major maintenace done on it. i've mentioned this problem and he will take a look at it. i'll tell you guys if he comes up with anything.
chris
Old Jul 19, 2003 | 02:37 PM
t-rex7's Avatar
It could be a bad thermosensor. (the sensor that is under the uim)
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
The1Sun
Sep 15, 2015 04:45 PM
firzen
Sep 15, 2015 12:04 PM
Monsterbox
Sep 11, 2015 03:29 PM
RotaryBobby
Sep 10, 2015 01:33 PM
