M.O.P. Questions
Old Jan 20, 2003 | 02:21 PM
yayo420's Avatar
Question M.O.P. Questions
Can I disconnect my MOP lines to the carb if i run pre mix? or can I disconnect it allltogether?.....Also I know this has been asked a thousand times but what is the ratio of oil/gas do I put in the tank.....ALSO...When I put on my new water pump the bolt that goes into the waterpump that holds the tensioner bracket to the alternator wont line up....It wont go in for ****....What should I do?....Please help me out guys!!-----Kevin
Old Jan 20, 2003 | 02:26 PM
error402's Avatar
#!/sup_mod/üb3rg33k
I use 1 oz. of two cycle oil to 1 gallon of gas.
-Error
Old Jan 20, 2003 | 03:51 PM
bliffle's Avatar
8 oz. of MMO per tank.
B
Old Jan 20, 2003 | 03:56 PM
85RX7GS's Avatar
I use the same ratio as error402 with the metering pump.
Old Jan 20, 2003 | 04:22 PM
yayo420's Avatar
Can I disconnect the MOP if I run pre mix?
Old Jan 20, 2003 | 04:27 PM
85RX7GS's Avatar
Yes
Old Jan 20, 2003 | 06:13 PM
yayo420's Avatar
Now what should I do about the tensioner bracket?
Old Jan 21, 2003 | 12:26 AM
yayo420's Avatar
I guess Im just fucked!
Old Jan 21, 2003 | 08:55 AM
error402's Avatar
#!/sup_mod/üb3rg33k
Why? Did you break something?
I run without the OMP and run premix. (I've been doing it for about a year now.)
I just opened up the OMP and took out the internals; then placed the original plate back on and finally connected a hose to the two nipples.
-Error
Old Jan 21, 2003 | 03:04 PM
yayo420's Avatar
Well this all started as a water pump replacement...When I was putting my alternator back on i found that the bolt that goes into the water pump that holds the tensioner bracket for the alternator wont go back in...its like the the water pump face and the "body" dont line up by like 1/16 of an inch.....Just enough to **** me off...im thinking of just carfully drilling into it to knock off that 1/16th.....The reason I asked about the MOP is cause when I was putting the alternator back on I some how snapped one of the lines...I was told I COULD NOT run w/out it or I would blow my motor....I guess it dosent matter for now cause I damn sure cant run w/ out an alternator.....Any Suggestions??????
Old Jan 21, 2003 | 05:52 PM
yayo420's Avatar
I fixed my prob w/ the bracket bolt.....I just beat the **** out of it till it fit.......AOK
Old Jan 21, 2003 | 08:40 PM
error402's Avatar
#!/sup_mod/üb3rg33k
-Error
Old Jan 21, 2003 | 08:54 PM
RotorMotorDriver's Avatar
Seven Is Coming
It is correct you should never run your engine without some sort of oil in there to lube stuff up. You can loose the OMP and just run premix in the gas. So if you want, just disable your OMP and run premix in the tank every fill up and youll be fine . Plus youll know that theres ALWAYS oil in there and youre not relying on some old thing that may not be pumping right anymore cause of a blown seal or something.
~T.J.
Old Jan 21, 2003 | 09:14 PM
yayo420's Avatar
Ove taken care of both my probs but I think Im gonna ****-can the mop anyway cause theres nothing safer than running premix.....one question though.....what grade should I use orshould I run something like MMO?....Thanks for the help.....
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
