Question involving steering adjustment
Old Jan 15, 2003 | 09:56 PM
mwpayne's Avatar
Admitted 'rexaholic'
In attempting to tighten up my steering (got nearly 2 inches of play), I loosened the nut, but the slotted screw in the middle turns with it. I've tried holding the nut with pliers, still mated together.
Question: Can I remove this altogether without forking up something in the steering box? I figure I'll have to take the nut assembly out to break it loose from the adjusting screw. I won't take it out until I know I can put it back in with no bad things happening.
BTW- Where do you add lubricant to the box? maybe in the hole when the nut is off?
Thanks!
Old Jan 15, 2003 | 10:31 PM
MosesX605's Avatar
My wife bought me 2 RX-7s
Your best bet is to check the Mazspeed site at www.mazspeed.com. Go to the facts section and check out the steering gear restoration. They content that using this procedure will give a better result than just adjusting the nut. They're pretty reputable, so it should work.
Good Luck
Matt
1979 SA22C
Old Jan 15, 2003 | 10:55 PM
mwpayne's Avatar
Hmmm, read it, I don't even know what the guy's talking about, WAY over my head and beyond my pitiful capablities!
Maybe I can find someone around here (yeah right).
Old Jan 15, 2003 | 11:01 PM
jerij's Avatar
MW,
Put a biga$$ screwdriver on the slot and turn the nut with a proper wrench. There is a limit to how far the slot will go before it bottoms out. To tighten the steering, you turn it clockwise. Hold it down good, then tighten the nut with the proper wrench.
Now, on the other hand...The "steering box fix" is HIGHLY RECOMMENDED. It is a little confusing but once you get into it, it will make sense. You won't believe what it will do for your steering either!
Then again, you can always buy a new box!
jeryj
Old Jan 16, 2003 | 07:32 AM
mwpayne's Avatar
Have you actually performed this procedure? I'd like to do it but I'll need better instructions w/ pics.
Know how I can get this help? Thanks!
Old Jan 16, 2003 | 12:12 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Tightening that screw adjusts the sector shaft engagement. Overtightening it to compensate for wear can result in binding and premature failure. The steering box is filled via that nylon plug on top of the box. Suck out the old 90W and replace it with Amsoil 75-90W gear oil. That's the best thing you can do for the steering box.
Old Jan 16, 2003 | 03:23 PM
mwpayne's Avatar
The nut and the screw are still locked together tighter than hat's dickband.
I still need to know if I can take this assembly all the way off without hurting something.
Maybe no one's tried it?
Old Jan 16, 2003 | 03:39 PM
Rx7carl's Avatar
Airflow is my life
No you cant take it all teh way out!!!!!!!!!! Follow the instructions at mazspeed. Take it a step at a time. SPray sone penetrant onto the screw and nut and let it sit.
Old Jan 16, 2003 | 09:19 PM
mwpayne's Avatar
Will do, thanks! Got the plugs out with ATF inside, 2 inches of snow outside. Good time to let it sit with liquid wrench.
I still need someone to 'hold my hand' and give me a
"Steering fix for dummies' translation of the mazspeed instructions.
Old Jan 16, 2003 | 09:27 PM
680RWHP12A's Avatar
use a 14mm open end wrench, loosen locknut and keeping the wrench on the nut use a screwdriver to turn the adjustment screw counterclockwise... it helps if you have somebody wiggle the steeringwheel back and forth while turning the screw.... after your done adjusting, hold the screwdriver and tighten the 14mm nut..... done!!!
Old Jan 16, 2003 | 09:32 PM
680RWHP12A's Avatar
one time a nut was stripped , instead of disassembeling the steeringbox we adjusted the screw then to lock the screw we used threadlock then some superglue, it worked fine and he is still driving it like that , 2 years later!! p/s the steering box is pretty inexpensive from the dealer $250.00 , one problem though .....its discontinued!!! no longer available
matty
Jan 18, 2020 10:39 AM
smikels
Rtek Forum
May 12, 2016 12:34 AM
ncds_fc
Sep 10, 2015 03:52 AM
c0rpse
Aug 25, 2015 11:50 PM
JIMMY54
Aug 12, 2015 05:40 PM
