12a tranny to 86+ 13b
Old Jan 5, 2003 | 11:07 PM
hornbm's Avatar
FD > FB > FC
Well I'm currious if my starter motor will work on the engine.
I have a 12a 5spd tranny hooked up to a 86 13b block.
The starter is from an 89 motor.
It seems to bolt up fine... but I havent tried it yet.
Will this combo work or will I need an FB starter?
Old Jan 5, 2003 | 11:57 PM
peejay's Avatar
Old [Sch|F]ool
Try it and find out!
There are two different 1st-gen starters, one with an 8-tooth gear and one with an 11-tooth gear. Since the flywheel diameters and starter cases are identical, the difference must be in the transmission case. FWIW my '80 had an 8-tooth, my '85 has an 11-tooth, and I don't know which year brought the change.
Old Jan 6, 2003 | 12:40 AM
Directfreak's Avatar
I am a Jeeper Now.
I think it may work. My friend's 87 GXL's starter screwed up, and I gave him the one from my GSL-SE, and it worked. (I have a TII starter now)
Then again, they were both 13B's with the larger flywheels than the 12A cars...
Old Jan 6, 2003 | 12:49 AM
Felix Wankel's Avatar
Super Newbie
An 83+ 12A would have the same size flywheel too.
Old Jan 6, 2003 | 11:52 AM
peejay's Avatar
Old [Sch|F]ool
All '74-up N/A have the same size flywheel.
Old Jan 6, 2003 | 12:04 PM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
I've got an RX4 starter in my 7 right now.
Old Jan 6, 2003 | 12:06 PM
peejay's Avatar
Old [Sch|F]ool
What year RX-7?
Specifically, what year transmission?
Old Jan 6, 2003 | 01:33 PM
nucentz's Avatar
would the 12a tranny bolt up to the t II 13b?
Old Jan 6, 2003 | 01:39 PM
peejay's Avatar
Old [Sch|F]ool
Yes it would.
The T2 flywheel won't fit in the N/A bellhousing, though. You'd need to get an N/A flywheel for it (use stock flywheel from same year, or get a N/A lightweight flywheel).
Make sure to have a good stock of transmissions on hand. The N/A RX-7 trannies are fairly weak, especially the later ones which have bearing problems and fine-pitch gears.
Old Jan 8, 2003 | 05:29 PM
hornbm's Avatar
FD > FB > FC
ok good, i just wasnt sure because of the 12a tranny if the 89 starter would reach the flywheel from the 86.
cleann88
Jan 15, 2022 11:28 AM
vy_MR2
Sep 16, 2015 06:39 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
