turbo cosmo
13B-RE mounts the same as an FC engine, no? Mounts to center housing.
Might not be a drop-in replacement for an FD, in other words.
But for an engine swap, hell why not... just scrape off the stock turbos and put something decent on there
Trending Topics
Originally posted by j9fd3s
you can use an fd housing, and a turbo 2 housing.
Well, if you wanted to put the engine in a FD and not have to fabricate a way of mounting it...
A used Cosmo engine, a new FD rear plate, and necessary gaskets, still come out to be cheaper than a used FD engine. What worries me is the intake port size/plcement... ah well.
I guess I kinda missed where you were going with that. If you know what FD intake ports look like on the outside I could go out to the garage and take a quick shot of my cosmo engine if you wanted to compare (intake is off right now). But I'm pretty sure cosmo/FD ports won't line up right with out a lot of porting.
mike
The FD (13B-REW) plates can be ported to the same size as the 13B-RE but it's a whole lot of work. Trust me I've done it!
On my FC I only had to fab one mount. I drilled and tapped the the bottom of the RE block to accept the factory passenger's side FC mount. On the driver's side I also used the factory FC mount but I added a little extra material so as to be able to use the bolts on the RE's block.
BTW. The process is pretty much the same when using the FD block in the FC chassis.
crispeed
87 Rx-7 TII
9.204@150.47mph
2600lbs
un-tubbed
crispeed
87 Rx-7 TII
9.204@150.47mph
2600lbs
un-tubbed
