turbo cotrol?
Old Jan 4, 2003 | 01:50 AM
jamespond24's Avatar
turbo cotrol?
Could a bad turbo control (next to the double throttle control) cause your primary boost?
Old Jan 4, 2003 | 03:40 AM
skunks's Avatar
I'm a CF and poop smith
what?
Old Jan 4, 2003 | 11:47 PM
I met primary boost to not boost like normal, like at 5psi?
Old Jan 5, 2003 | 06:41 AM
Da Man's Avatar
Your car is most likely in limp-home mode. This means that the wastegate is stuck open. This could be because the primary turbo wastegate control solenoid is closed. It could also be a problem with the wastegate actuator or the rod or the wastegate itself...
Old Jan 5, 2003 | 07:27 PM
rpm_pwr's Avatar
over what rpm are you getting 5psi?
Anyway stock wastegate is 7psi. If you're getting 5psi then you have a boost leak. End of story.
-pete
Old Jan 6, 2003 | 02:23 PM
Da Man's Avatar
Sorry about that, I was thinking 0.5bar when I saw the "5"... Yep, boost leak it is.
FD7KiD
15
Feb 26, 2021 10:12 PM
Th0m4s
Feb 26, 2019 02:04 AM
C. Ludwig
Jan 30, 2019 06:31 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
FD7KiD
Aug 17, 2015 11:50 PM
