Rattle
Old Dec 12, 2002 | 12:52 AM
KIRKS7's Avatar
Rattle
My 84 GSL hows a really bad metal rattling sound on the right front side.
I played with idler arm if moves quite easly up and down.
Also when I push on the tire towards the engine it has some play.
Also if I'm at a light standing still and turn the wheel hard I can hear metal hitting metal.
Any suggestions?
Old Dec 12, 2002 | 01:55 AM
marshp's Avatar
Registered Rx7 Owner
maybe it could be worn bushings??
thats my thought
Old Dec 12, 2002 | 08:13 AM
djmickyg's Avatar
check all ur tie rods and stering arms? and see if there are any broken or torn rubber boots anywhere that are letting durt in?
Old Dec 12, 2002 | 09:25 AM
85RX7GS's Avatar
The steering components need to be replaced - that's what it sounds like at the least.
Old Dec 12, 2002 | 11:13 AM
Wankelguy's Avatar
My FSP Fiesta eats Jettas
Yep, sounds like you've got no idler arm bushings left. Easy fix, though, just replace the bushings if the housing isn't too worn, or replace the entire idler arm.
-WG
Old Dec 12, 2002 | 06:06 PM
LongDuck's Avatar
84SE-EGI helpy-helperton
Idler arm bushing procedure:
1) remove cotter pin from top of idler arm.
2) remove castle nut and washer from top of idler arm
3) remove remains of bushing at top and bottom of idler arm by removing arm, downward
4) replace idler arm bushings, bottom first, then insert idler arm into mount.
5) apply grease to inside of mount
6) install top idler arm bushing
7) install washer and castle nut
8) install cotter pin to keep castle nut from turning.
You're done. Get the parts from local Mazda dealer ($6 each x2), or Mazdatrix. HTH,
Old Dec 12, 2002 | 06:11 PM
my rear end near the gas tank rattled alot becuase the mettal was realy close, i bent it apart and bingo, rattle gone.
Old Dec 12, 2002 | 08:30 PM
Keaponlaffen's Avatar
You bent your rear end apart and made it loose, and it fixed the rattling in your gas can? Hmmm.... That kinda goes along with the blown seal thing...
Jeff
Old Dec 12, 2002 | 09:49 PM
Wankelguy's Avatar
...Yes, it's hard to get the nut off.
vipernicus42
Mar 7, 2016 04:57 AM
breakfast
Sep 20, 2015 07:06 PM
Rotospectre
Sep 13, 2015 11:22 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
vipernicus42
Canadian Forum
Sep 5, 2015 09:37 AM
