Finally put back together ported engine, and finally back in car.
Old Dec 2, 2002 | 09:16 PM
lerch32's Avatar
Just thought I would share some pics. I am finally seeing the light at the end of the tunnel. Here is the engine.
Old Dec 2, 2002 | 09:20 PM
lerch32's Avatar
Her are BNR's stage 2, that I installed.
Old Dec 2, 2002 | 09:23 PM
lerch32's Avatar
Here is a pic of some of the porting I have done to the turbos.
Old Dec 2, 2002 | 09:26 PM
lerch32's Avatar
Before the install.
rx7raca's Avatar
wHiTe kNiGhT
looks nice man, give us some dyno reports when everything is done
Old Dec 2, 2002 | 09:32 PM
lerch32's Avatar
After the install.
Old Dec 2, 2002 | 09:37 PM
jhammerrx7's Avatar
I Like Guns
I have a mild streetport from Atkins and I believe that you really can tell a difference. Get it on the dyno and get us some numbers.
Old Dec 2, 2002 | 09:39 PM
jhammerrx7's Avatar
I Like Guns
The pics of your engine bay look great. I am getting my car repainted this winter and I am thinking of doing the engine bay also. Did you do all of the sanding and taping in the bay?
Old Dec 2, 2002 | 10:10 PM
silver93's Avatar
looks like you were able to mount the engine to the engine stand without a special adaptor ? i have the same engine stand and need to mount mine - am i missing something or can itbe done without the adaptor?
Old Dec 2, 2002 | 10:11 PM
silver93's Avatar
looks like you were able to mount the engine to the engine stand without a special adaptor ? i have the same engine stand and need to mount mine for teardown and rebuild- am i missing something or can it be done without the adaptor?
(btw, nice looking engine)
Old Dec 2, 2002 | 11:13 PM
lerch32's Avatar
I disassembled, and reassembled the engine without an adaptor. I just bought the right size bolts I needed for the stand to attach to the front plate. Just make sure that they are tight.
Old Dec 2, 2002 | 11:52 PM
ArchangelX's Avatar
Bravo! Looks great...did you do the engine high temp paint yourself?
Old Dec 2, 2002 | 11:57 PM
Fd3BOOST's Avatar
Recovering Milkaholic
Looks killer bees Rob.
I am impressed. It's kinda funny though I though I would get mine done first. But since I am stuck buying alot of parts and I did all the porting on the enigine myself It took slightly longer than I hoped.
I'm only shy a clutch and a radiator now.
check my project if you like in the NE area at no pistons .com forums.
-Dave
Old Dec 3, 2002 | 12:33 AM
Mercury's Avatar
Who did the porting? Everything looks clean... I like the black engine bay... might I ask what is the original color of the car? Looks good! Cant wait to see your dyno #'s.
-M
Old Dec 3, 2002 | 02:24 AM
lerch32's Avatar
I have done everything to the car, except for the porting. I had Bryan at BNR do that, along with the turbos. The engines are alot simpler then poeple think. Hope to get her to the dyno in the near future. Hopeing for at least close to 400 rwhp.
Old Dec 3, 2002 | 06:15 AM
silver93's Avatar
cool- do you recall what size bolts you used?
Old Dec 3, 2002 | 07:29 AM
half past twelve's Avatar
looks PURDAY...
Old Dec 3, 2002 | 09:11 AM
rotorbrain's Avatar
fart on a friends head!!!
its a 12mm x 1.25 bolt i believe. doing the engine that way works, but it is dangerous. make sure you have sturdy equipment. my engine is on the stand being torn apart and one of the brackets is bending!!!! not cool. the rotary engine stand heads are made a way that balances the engine. the engine is very hard to flip if its done this way. if youre doing it once and thats it. . . then by all means do it this way. just be careful. . . that engine stand will tip if not watched.
paul
Old Dec 3, 2002 | 09:40 AM
7sweetie's Avatar
Pilots are hot!
as soon as you dyno, let us know, im really curious to see how the bnr stage 2 turbos perform. i've heard some good things but then i've heard that there isnt a huge difference. btw, love the color
Old Dec 3, 2002 | 03:53 PM
lerch32's Avatar
The car was black.
alphawolff
Nov 17, 2015 05:57 PM
ncds_fc
Aug 15, 2015 10:06 AM
Wolf_
Aug 11, 2015 04:23 PM
