Non responsive boost sometimes
Old Nov 1, 2002 | 07:25 PM
DavidDeco's Avatar
I have more fun than you.
Basically I notice often that if I am cruising (not in acceleration already) at like 3500-5000 rpms in 3rd or
4th gear and then go WOT, my boost climbs to 0-5 psi and rpms increase only. Little or no turbo response.
When I let off the accelerator I hear the "whooo" sound.
It doesn't do this all the time, but I notice it on the highway. It seems like my car needs to be running a bit
before it starts doing it but once it starts it does it
conistently every time.
I've taken it to 2 Rx-7 specialists and neither have been able to figure out the issue.
Any ideas?
David
Old Nov 1, 2002 | 07:31 PM
DavidDeco's Avatar
A few mod notes would help...
Power FC
Profec B
Stock turbos
Pettit IC "3"
I had this problem when my Profec B was not working
and had to control with the PFC. The 2nd guy I took
it too said he removed the PowerFC from the boost
control loop and set up the Profec B not as standard but as he would set up an Apexi controller....for what its worth.
Anyways I still have this issue.
Old Nov 13, 2002 | 12:38 PM
DavidDeco's Avatar
help, please??!! Any ideas?
Old Nov 19, 2002 | 10:08 PM
DavidDeco's Avatar
final plea for help?!!?
any guestimates at least?
Old Nov 20, 2002 | 08:43 AM
Lost Time's Avatar
Chimera Driver
If you're still running the seq sysytem sound slike your've got a hose blown off. I'd check all the hoses related to the CRV. You might find on that's not connected.
24seven_dada
20
Nov 10, 2018 12:03 PM
alexdimen
20
Oct 23, 2015 01:50 PM
Clacor
Sep 11, 2015 08:36 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
