Can some please explain this (tranny differences)...
Old Oct 20, 2002 | 12:39 PM
SPDSTR 7's Avatar
Why does a TII tranny fits on NA engine but not an NA tranny to a TII engine? I know that the NA tranny is weak for a TII but I'm asking about the fitment. Or does a TII tranny fits on NA?
Old Oct 20, 2002 | 12:51 PM
Cosmo Donk's Avatar
Queer
The NA tranny will bolt up to the T2 engine just fine. Maybe there will be a bolt in a different place on one but it will still bolt up. I think no one bothers because they are supposedly weak.
Old Oct 20, 2002 | 12:57 PM
SPDSTR 7's Avatar
wow, that's good to know. Well, maybe just for a project, I'll try to drop in a TII engine on my NA. I'm just wondering how long the tranny will hold up.
Old Oct 20, 2002 | 01:04 PM
Cosmo Donk's Avatar
Queer
There are people who have done it. I know a dude with an SC on his, maybe it is still there, and it worked fine.
Old Oct 20, 2002 | 01:05 PM
SPDSTR 7's Avatar
Cool. Thanks man. A "turbocharged NA" project will start soon
Old Oct 20, 2002 | 02:05 PM
HuggyBear's Avatar
the bolt pattern is different at the rear end. its not a bolt on situation.
this info is assuming you are just swapping the tranny. my swap to a turbo tranny involved extending the bolt pattern and reinforcing the flange. simple job.
Old Oct 20, 2002 | 02:11 PM
SPDSTR 7's Avatar
Well, what I was asking was if I can drop in a TII engine on NA without replacing the tranny.
Old Oct 20, 2002 | 02:31 PM
hypntyz7's Avatar
This is the deal. The bellhousing bolt pattern for all rotary transmissions is the same. However the crossmember mounting position, crossmember itself, driveshaft yoke diameter, driveshaft length, rear driveshaft flange diameter, etc. are all different depending on year and model.
SO technically an NA tranny will bolt to a turbo engine, but it could not be installed in a turbo car. A turbo tranny will bolt to an NA engine, but it will also not work in an NA car. This is why you hear of people doing driveline conversions...everything from the flywheel back is different between a turbo adn nonturbo model...all the turbo stuff is larger.
You can use a turbo engine in your NA car using the NA drivetrain, but your clutch will slip like MAD. www.rotaryresurrection.com tech section under stage 1 turbo conversion.
Old Oct 20, 2002 | 02:43 PM
knight1976's Avatar
Would it still slip with an upgraded clutch?
Old Oct 20, 2002 | 02:56 PM
hypntyz7's Avatar
Depends on the clutch, the driving style, and the engine mods. I did the swap once with a stock t2 engien and stock na clutch, and it slipped like mad. It would break loose in any gear after 4krpm, even if I eased the clutch out at takeoff/shifts before applying any throttle.
I'd say something like an act HD PP and 6 puck clutch would handle the powre just fine, until your tranny broke. IF youre gonna mod the t2 engine for 300hp though, even that might not hold.
Old Oct 20, 2002 | 03:15 PM
RotorDemonGXL's Avatar
I'd be safe and go TII the whole route. If your gonna Turbo the motor, might want to stick with the TII tranny and a TII rear diff. Aaroncake is the guy to talk to on this one... If I'm not mistaken his NA/TurboII Swap is stickied somewhere.
Old Oct 21, 2002 | 06:48 PM
SPDSTR 7's Avatar
ok, just for me to understand it completely, I can just drop a TII engine on my NA without modifying the drivetrain right? I have an ACT HD SS clutch right now and that should do it ok I guess for now.
Old Oct 21, 2002 | 07:49 PM
I wish I was driving!
if you swap on the NA flywheel, yes.
Old Oct 21, 2002 | 09:20 PM
SPDSTR 7's Avatar
Ok, so the NA flywheel can be bolt on to the TII engine?
Old Oct 21, 2002 | 09:52 PM
Cosmo Donk's Avatar
Queer
Check the weights of the flywheels because the have the counterweights integrated in them. I am not certain so hopefully someone else will see this for the answer If the weights are the same then knock yourself out
Old Oct 21, 2002 | 10:00 PM
counterweights are the same within series.
Thus, if you have an S5 TII engine, you need an S5 NA flywheel. Tranny series doesn't matter, only the engine and the flywheel series must match.
Old Oct 21, 2002 | 10:08 PM
SPDSTR 7's Avatar
These are great info guys. Thanks for all your replies. I'm gonna rate it a 5 star
rgordon1979
40
Mar 15, 2022 12:04 PM
sinclair7seven
11
Sep 11, 2015 10:15 AM
AXA
Sep 5, 2015 10:06 AM
