Dowel pins
Old Oct 14, 2002 | 08:06 PM
now's Avatar
now
Dowel pins
I have a question about the dowel pins in the 20b
they look to be the same as the 13b pins.
they are the same length and di. except for the 2 pins in
the front rotor housing, these ones have a step on them
where they go into the wide housing at the front.
the di. steps down 6/1000 of a inch.
check out the pics.
matt
Old Oct 14, 2002 | 08:07 PM
now's Avatar
now
and another pic
Old Oct 14, 2002 | 08:10 PM
now's Avatar
now
forgot to say, the normal pins will go into the holes
where the ones with the step were in..
just wondering if I shouldn't use normal pins in these
holes, you wouldn't think that loose pins would be good,
but mazda must have used them for a reason.
matt
Old Oct 15, 2002 | 12:18 PM
j9fd3s's Avatar
Community Builder
thats weird, i would just put it back the way you found it
mike
Old Oct 15, 2002 | 06:11 PM
RETed's Avatar
Weird...
Looks like Mazda wanted the extra strength.
0.006" is super tiny - it might be just to show which side is "front"?
-Ted
Old Oct 17, 2002 | 07:34 PM
now's Avatar
now
well talked to a mazda tech on the phone today and was told
that the front dowel pins are different for a reason
and that regular pins should not be used in their place.
there was no explanation for the difference (didn't know)
just to use the ones that mazda put there.
they show up in the parts book as different part number
from the rest in the motor, so its not just my motor that
has them.
matt
Old Dec 24, 2002 | 09:00 AM
Hey I don't know if you figured this out already but the step down portion of the pin goees into the front rotor side of the large side housing. If you need a better explination I can give you one. Anyway, I measured the distance the down pin goes in the holes and the tapered side goes in about 1.5-2mm more than non tappered side. So those must go there or the housings wont go together right. Hope this helps.
Old Dec 24, 2002 | 12:00 PM
now's Avatar
now
I have been told no replace these pins with standard
no step pins.
matt
Old Dec 25, 2002 | 08:14 AM
All I know is the step pins definately go in further in that specified location. Also, We called several different places and they also told us to use them in that spot.
Old Dec 25, 2002 | 10:28 AM
now's Avatar
now
I know that in the later motors c's and d's the front pins are the same as the rest, not sure why the change but
mazda stoped using them.
matt
Logan Reinisch
44
Sep 17, 2018 12:20 PM
Coochas
Oct 3, 2015 04:49 AM
Sh00bs
Oct 1, 2015 11:57 PM
