2nd thing broke on Cosmo POS :( Im starting to get pissed
Old Oct 14, 2002 | 08:03 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I was just cruising around taking it VERY VERY easy on the car, coming out of target I start the car up, and the car starts pissing 4 quarts of ******* motor oil all over the motor and the ground...
Its all from the passenger side, looks like a oil line? But the top oil line looks fine and the bottom one is on there and is intact... Hope it didnt just blow the oil seal out of the turbo
We'll see... Had the car towed home, so add $35 to the total so far
Signed mucho mucho pissed off
Old Oct 14, 2002 | 08:12 PM
Felix Wankel's Avatar
Super Newbie
I'd check the oil supply line to the turbo.
Old Oct 14, 2002 | 08:32 PM
MIKE-P-28's Avatar
DING DING DING, give this man a bud lite, the oil supply line split clean open.. I thought that oil hose would have been tougher than that for 100 miles... But it split clean open...
Guys how would you go about cleaning up this mess. Its all over everyhting Im mean wipe it off and its shiney LOL But its gonna gather dirt or something?
Spray is off with some Gunk or somehting?
Damn and its all in my K & N too
Oh well thats what I get for not making muy own line, and just using rubber
Old Oct 14, 2002 | 09:20 PM
S2-13BT's Avatar
Man that sucks! Sounds like it's time for some braided stainless steel lines.
Don't worry though, it'll all be worth it in the end. There'll always be little probs that need sorting with projects like this I suppose.
Old Oct 14, 2002 | 09:26 PM
MIKE-P-28's Avatar
Its kinda odd fitting, its a flanged end and some sort of brake line looking fitting on the other end. Wonder if I took stainless steel braided stuff and band clamped it with a machine, if it would work.. Its working perfectly on my oil cooler hoses ..
Old Oct 14, 2002 | 09:32 PM
82transam's Avatar
Never Follow
That sucks man. Engine degreaser should take that oil off. Guess you'll have to replace the air filter if its covered in it.
Old Oct 14, 2002 | 09:36 PM
MIKE-P-28's Avatar
Probally just spray it out with K & N cleaner, should be OK... Its not soaked, I can still see through it
Directfreak's Avatar
I am a Jeeper Now.
Mike, a lot of guys around here use the stainless steel autometer braided line (used for gauges) to feed the turbos. It's a -4.
Just a thought for a quick and easy replacement.
Old Oct 14, 2002 | 09:38 PM
MIKE-P-28's Avatar
Well its flanged on one end and that flared brake fitting looking thing on the other, think stainless braided crimped with a hydralic crimper would do it?
Old Oct 14, 2002 | 09:43 PM
I am a Jeeper Now.
You tell me.
Old Oct 14, 2002 | 09:44 PM
82transam's Avatar
Never Follow
ah, ok, that should be ok then
Old Oct 14, 2002 | 09:47 PM
MIKE-P-28's Avatar
You tell me.
Thanks for the pic , but I dont think that will work on mine LOL I need to take a pic of it
Old Oct 14, 2002 | 10:41 PM
Super Newbie
Does it look like a TII one? They have a banjo fitting on the front plate, and a male flare on the other end. Most people use those with a piece of SS line threaded right into the center housing instead of using that 90* piece with the two 12mm bolts.
Old Oct 14, 2002 | 10:55 PM
MIKE-P-28's Avatar
looks eaxctly like that, but my stock piece from the front side housing doesnt do 2 90's, it comes stright out, thus the reason I had to 1/2 the t2 oil supply line in 1/2 and splice with hose..
Battery is dead in the camcorder, so I cant take picture
Old Oct 14, 2002 | 11:11 PM
Super Newbie
If you want to be fancy you could put a fitting on the end of the Cosmo supply line and run some ss line to the turbo.
Old Oct 15, 2002 | 08:28 AM
MIKE-P-28's Avatar
Yeah could get real fancy like setzep and weld an AN fitting onto the stock banjo part at the front of the motor and run all AN line to the turbo
Old Oct 15, 2002 | 08:47 AM
RotorMotorDriver's Avatar
Seven Is Coming
Just so you know...We had a K&N filter fall off a work bench into an open oil drain pan. It got SOAKED with oil. We just let it drip dry for a while and then used the filter cleaner a couple times (follow the directions, let it dry each time) and it looked fine. We oiled it and stuck it back in the car (85 GSL-SE). Works fine. If anything, Id say the motor oil helps catch the dirt along with the K&N oil you're supposed to use on it, lol.
~T.J.
PS - We also took it out shortly after (a couple weeks) and cleaned it agian just to be sure .
Old Oct 15, 2002 | 10:19 AM
Hans's Avatar
carb clener, berrimans(sp?) flavor gets most stains, oils up. so does brake parts cleaner from orielys, but both probably strip paint so Buyer beware, or something.
engine degreaser sounds like a good shot
Old Oct 15, 2002 | 12:20 PM
MIKE-P-28's Avatar
ok engine bay is now washed up and drying, the K & N is drying now, getting ready for oil , and the new turbo oil supply line is now on
I only lost 2 1/2 quarts of oil , so that explains why I still had oil pressure Shheeewww, this could have been really really bad.. Not to mention oil will start fires too
So might not be a bad idea to have my fire ext checked out
Old Oct 15, 2002 | 07:39 PM
setzep's Avatar
Oops, that's one of the main reasons I'm running tubing from the front plate all the way to the turbo. It would take 15,400psi to burst my 1/4" .035 wall tubing, think I'm safe?
Old Oct 15, 2002 | 08:27 PM
MIKE-P-28's Avatar
Yeah Id say, I got some oil hose on there rated for 250 psi, 320 degrees
cristoDathird
28
May 30, 2019 08:47 PM
alphawolff
Nov 17, 2015 05:57 PM
smikels
Aug 18, 2015 01:26 PM
