relationship between compression and vacuum...?
Old Oct 8, 2002 | 08:28 PM
potatobbq's Avatar
is there any sort of relationship between compression and vacuum at idle? would it be correct to assume that a car with low compression, should have low vacuum at idle? say for example... an engine with a compression of 55-60psi (low compression), how much vacuum would i expect to see at idle... or would compression that low even allow the car to start...?
Old Oct 8, 2002 | 09:58 PM
spooledUP7's Avatar
There and back again
Good question, but I don't know the full answer. What I do know is, yes, compression has a relationship to vacuum, but so does air flow. High flow exhaust and intakes can cause lower compression by virtue of less restrictions.
Here's something to keep in mind about low compression rotary engines; normally only one seal causes it, and two rotor faces feel it. So, if you had low compression you would most likely see a fairly noticeable fluctuation in vacuum as the higher rotor face passes. Sorry I could not help.
Old Oct 8, 2002 | 10:17 PM
ttb's Avatar
ttb
No Cup Holder Racing
i thought an engine with good compression would see higher vacuum?
Old Oct 8, 2002 | 10:55 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
That is correct. I think Goodfella had a poll going somewhere, where people posted their vacuum readings that they were seeing on their PFC.
Old Oct 8, 2002 | 10:56 PM
Dr Wankel's Avatar
Altitude SUCKS!!!
here it is https://www.rx7club.com/forum/showth...acuum+readings
turbodreamz22
28
Nov 10, 2023 11:08 AM
Andrew7dg
Aug 6, 2017 01:41 PM
93FD510
Oct 1, 2015 02:00 PM
