What else can I do to make my car quicker?
Old Oct 3, 2002 | 12:01 AM
koukifc3s's Avatar
Clogged cat
Hey, I have an 89 GXL with the following mods:
Bonez Race Pipe
Racing Beat catback
Cone filter
ghetto tuned S-AFC
With that I can beat an n/a 300ZX but I still want more power!
Is there any other bolt ons I can get to get some more hp?
Thanks!!
Old Oct 3, 2002 | 12:07 AM
NRA T2's Avatar
porting, advance timing, super or turbocharge
Old Oct 3, 2002 | 12:22 AM
Roy James's Avatar
My cars louder than yours
get a header, port/polish your manifold, remove your air pump and install an electric air pump, get some high power ignition system, lets see.... get a nitrous oxide system, pull an Aaron Cake, get a wide band O2 sensor and un "ghetto tune" your S-AFC and tune it right.
If none of that satisfies your thirst, maybe you should start working on lightening/stiffening up your car. Get a good solid suspension system under there (not that the stock RX7 suspension sucks... just.. there is always better)
Good luck and have fun.
Or TII swap and sell me your block for 300 bucks...
Old Oct 3, 2002 | 12:25 AM
NRA T2's Avatar
You forgot something, have you seen those awsome wings all those fast *** Hondas are using, it'll knock a sec. off your 1/4 mi.!!!
Old Oct 3, 2002 | 12:30 AM
MtnRacer's Avatar
infini guru
Weight reduction will be your cheapest route. A/C, Power Steering, insulation, etc. After that, spend time learning how to tune you AFC better... After that, maybe underdrive pulleys if you're serious about this power thing. Everything else is going to start getting really expensive. Hope this helps!
Steve
Old Oct 3, 2002 | 12:36 AM
NRA T2's Avatar
but what about the wing??
Old Oct 3, 2002 | 12:37 AM
von's Avatar
von
4.3 gears or mazdaspeed7 tranzmission with FB gears.
Old Oct 3, 2002 | 12:45 AM
Rs4Racer's Avatar
how much power can you get out of a n/a..
realistically speaking.
oh thats without bridgeporting or pp but street porting is ok.
Old Oct 3, 2002 | 12:49 AM
RotorMotorRX7's Avatar
Turbo is GOD!!!!
Find a junked Turbo II and take what you need, and yes i do realize thats easier said than done....
Old Oct 3, 2002 | 02:44 AM
13bpower's Avatar
s4 for life
The most I have seen, Dyno proven, on this site is 170 at the wheels. That car still had some modding left. I would guess 175 would be a good estamate.
Old Oct 3, 2002 | 02:48 AM
Rs4Racer's Avatar
Thanks.
i was really hoping it would be closer to 210.
I guess i will have to go with tII now.
Old Oct 3, 2002 | 02:53 AM
13bpower's Avatar
s4 for life
It's all about how much money you want to put into it. A turbo will get you power cheaper.
A N/A starts out with 120hp (s4), and 128hp (s5) at the wheels.
If you wanted to speed big money I'm guessing you could squeez as much as 190whp out of a N/A. For the same money you could get 300whp on a turbo.
Old Oct 3, 2002 | 08:00 AM
silverrotor's Avatar
How about de-ghettoing your S-AFC and get It Dyno tuned so your car can have It for what It's really worth.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
astrum
24
Nov 15, 2017 08:44 AM
dkwasherexd
May 27, 2017 04:51 AM
