1980 w/13B 4 port
Old Sep 27, 2002 | 05:22 AM
gonzz's Avatar
1980 w/13B 4 port
I got a 1980 Rx-7 w/13B 4 port installed. Can't get my eng temp gauge to work. anyone have this setup.. Can you give me some advise? Below oil filter should be eng temp sensor right? Can i ground out harness wire and gauge will move to make sur ei got right wire??
Thanks, Gonzz
Old Sep 28, 2002 | 12:28 AM
gonzz's Avatar
I know someone has done this..
Old Sep 28, 2002 | 12:32 AM
Directfreak's Avatar
I am a Jeeper Now.
What year engine do you have? I believe pre-1980's did not have a spot on the rear housing for temp or oil pressure.
Old Sep 28, 2002 | 12:40 AM
gonzz's Avatar
it's a pre-80.. not sure exact year.. there is a sensor below filler neck.. just a blade type..
Old Sep 28, 2002 | 01:00 AM
DriveFast7's Avatar
Blood, Sweat and Rotors
on a 12a and a rotary pickup 13b 4port i worked on last week theres a big brass electric sender with a fat round end that threads into the rear side housing. on the fat round end there is little round circle protusion. u slide the female connector (that looks like it's for a blade connector) right onto that little round circle protusion.
now on 12a water temp is on the same rear side housing and is a little spud that you pop a female roundy connector onto. don't remember about the 13b 4port but i'd bet its similar.
if ur going to sevenstock tomorrow just call me on my cell and i'll come over and help out. later gonz!
-brad-
Old Sep 28, 2002 | 01:14 AM
gonzz's Avatar
I'll be there.. See yah
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
josef 91 vert
14
Sep 17, 2015 09:22 PM
Josh83rx7
Sep 15, 2015 10:23 AM
JGLawson
Sep 13, 2015 03:23 PM
