FC RX-7 Hitachi Turbo Specs
Old Sep 27, 2002 | 04:28 AM
dorikin ichiban's Avatar
Does anyone have the specs of these turbos?
A/R? Inducer, Exducer?
Cheers
Old Sep 27, 2002 | 05:55 AM
HWO's Avatar
HWO
inteligent extratarestril
hmm fellow kiwi......
Its a T3/T4 set up
exhuast housing is a 0.88a/r
turbine inducer is 64mm
turbine exducer is 53mm
compressor inducer is 44mm
compressor exducer is 63mm
6mm tip gap on the comp wheel
not sure on the A/R of the comp housing
compressor would flow approx 280HP on a piston engine.
Old Sep 27, 2002 | 11:48 AM
SaabGuy's Avatar
.88a/r??? Are you sure?? I've heard 1.00 on both the s4 and s5 turbo.
Old Sep 27, 2002 | 01:10 PM
fastrotaries's Avatar
W. TX chirpin Monkey
1.0 wow that seems a little big. I have a spare 1.0 housing (Garett) and it's WAYYY bigger than the stock one. what i'm using now is a 1.15 and it dwarfs the stock one. .88 even seems a little too big for me.
Old Sep 27, 2002 | 03:26 PM
FC Drifter's Avatar
Damaged Little F*cker
i believe, but am not positive, that the 87-88 turbos were the .88 A/R and the 89-91 turbos were the 1.0 A/R. i could be wrong though, and probably are wrong
Old Sep 27, 2002 | 05:40 PM
BlackFC's Avatar
A/R is a ratio, .88A/R on a T3 hotside and .88A/R on a T4 hotside with completely different exhaust wheels, will yield completely different housings. I have always heard .88 for the S4 and .96 for the S5.
Old Sep 27, 2002 | 06:07 PM
Felix Wankel's Avatar
Super Newbie
Its a .88, look how flat a series 4 turbine housing is compared to a series 5.
Old Sep 30, 2002 | 04:32 PM
RETed's Avatar
You can't compare A/R number from different models/sizes of turbos.
Yamaguchi book clearly states turbine A/R = 1.00.
-Ted
Old Sep 30, 2002 | 05:10 PM
IAN's Avatar
IAN
Rotary Reborn!
Then when I buy a T04E with an A/R ratio of .96 what would be the point if and S5 has an A/R ratio of 1.00??
Ian Skacel
Old Sep 30, 2002 | 05:22 PM
peejay's Avatar
Old [Sch|F]ool
Because A/R is just a RATIO... for what it's worth I have a turbo that practically fits in the palm of your hand (might be good for one rotor of a 10A!) and it has a 1.0 a/r ratio.
Old Sep 30, 2002 | 05:32 PM
rotarygod's Avatar
Rotors still spinning
A 1.0 a/r on an O trim is small.
A 1.0 a/r on a P trim is bigger.
A 1.0 a/r on a Q trim is bigger still.
...and so on. Find out what the equivalent trim would be for the stock turbos. (Don't know if there is an accurate comparison.)
a/r stands for area/radius of the housing. Obviously this would differ depending upon the size of the wheel.
If someone advertises a T-04E for sale and says it has an exhaust a/r of .96 that tells you NOTHING useful without knowing what trim the turbine is. You need more information.
If I were just to pose the question of "How much power does my 13B make?" no one could answer it until they had more details on it. Same thing with turbos.
sherff
Feb 24, 2019 12:09 PM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
