New Cat
Old Sep 24, 2002 | 09:47 PM
toasty's Avatar
Question New Cat
Today I installed a bonez dual cat and the racing beat cat-back on my '88 se.
When I started the car, it smelled (I hear this is normal with a new cat) but also some black smoke was coming from both ends of the cat. Is it from the gasket or cat breaking in or do I have a problem?
Old Sep 25, 2002 | 12:51 AM
toasty's Avatar
ttt and i'm off to bed
Old Sep 25, 2002 | 09:40 AM
Mulligan22's Avatar
Both ends of the cat? The smell is normal. Check for leaks and after a week or so things should settle in.
Old Sep 25, 2002 | 10:24 AM
DaleClark's Avatar
RX-7 Bad Ass
There will typically be dust and debris in the exhaust system from the factory that will take some time to burn off and blow out.
If the car sounds right and you don't have exhaust leaks around the cat, I would guess it's just stuff on the outside of the cat burning off - oil from production, grease from your hands, whatever. Cats get *REALLY* hot.
Dale
ls1swap
Jun 3, 2024 03:25 PM
Andrew7dg
Aug 6, 2017 01:41 PM
