Exaust Port / Flow Idea (more power without dissasembaly?)
Old Sep 24, 2002 | 09:04 PM
nimrodTT's Avatar
all aboard!
You wouldn't see any gains by removing the exhaust sleeve in a stock port motor. In fact you wouldn't see any gains unless you're running a huge ported motor because the flow is restricted by the port shape and size, not that sleeve.
Old Sep 24, 2002 | 09:39 PM
MIKE-P-28's Avatar
Driven a turbo FB lately?
I dunno on a 12A , but on a 13b 4 port they are pressed in and retained with a standard roll pin, you have the have the housings diasembled to remove the roll pins
Old Sep 24, 2002 | 09:59 PM
diabolical1's Avatar
Originally posted by 13K ReDLiNE
I wanna try if possible, every lil bit helps
i believe they are attached the same way on a 12A because i've heard them rattle when they are loose. you have to take the motor apart to get them out.
however, as nimrodTT pointed out, there is little (if anything) to be gained by removing them. you will be allowing more heat to radiate through the rotor housing than is desireable ... and that would spell LOSS, sooner or later.
Old Sep 24, 2002 | 10:36 PM
nimrodTT's Avatar
all aboard!
They are roll-pinned, but I can think of at least a few ways to remove them with the engine together. But just to warn you, the will port velocity will be decreased and I would be surprised if you didn't lose power by removing them.
Old Sep 25, 2002 | 03:24 AM
rotarygod's Avatar
Rotors still spinning
If you remove the sleeves and do no porting at all then you will lose power everywhere. Leave them in.
C. Ludwig
Jan 30, 2019 06:31 AM
sYnth.
Aug 17, 2015 07:28 PM
andyvideopro
Aug 11, 2015 09:16 PM
