Just finished installing my S-AFC...
Old Sep 20, 2002 | 08:37 PM
SPDST3R's Avatar
Thumbs up Just finished installing my S-AFC...
... and everything seems to be working. Now I'm ready for the dyno tomorrow to set it up. One noticed though when I was checking the RPM on the S-AFC. It is not the same with the stock gauage. At idle, my stock gauage reads +- 750 while the S-AFC stays around 500. Is this normal or something is wrong with my stock RPM gauage? It hink 500 at idle is really low. Any idea guys?
Old Sep 20, 2002 | 08:47 PM
S-AFC
Let me know what your settings are on yours because I have similar mods and I don't have a dyno close by.
I have also noticed the difference in rpm readings. I think that the S-Afc is more accurate because it is just a digital reading straight from the ECU but without the guage that could or could not be accurate getting in the way.
Old Sep 20, 2002 | 09:29 PM
pp13bnos's Avatar
Pineapple Racer
My s-afc is reads pretty close to idle, but way up around 8,500 its off a couple hunderd rpms. O-well. I trust the s-afc over the stock 12 year old tack. CJ
Old Sep 20, 2002 | 10:03 PM
Scott 89t2's Avatar
SOLD THE RX-7!
my idle is dead on but anything over 2000rpm is off by 200-400rpm.... the afc will be right.
Old Sep 20, 2002 | 11:04 PM
SPDST3R's Avatar
ok, i took her out for a spin and here are some reading comparisons:
750 (stock) - 500 (safc)
3500 (stock) - 2600 (safc)
4500 (stock) - 3000 (safc)
as you can see, it is over 1000 RPM off.
Old Sep 20, 2002 | 11:42 PM
bcty's Avatar
Boost This!
that is concerningly off... might wanna check that your S-AFC is hooked up right.. to be off by 1000 at that rpm seems pretty bad for the stock gauge..
Old Sep 21, 2002 | 02:13 AM
SPDST3R's Avatar
i had the cylinder wrong. it was setup for 6 instead of 4. So I put it to 4 and everything is now in sync
Old Sep 21, 2002 | 02:25 AM
silverrotor's Avatar
When you say In sync, like 750rpm (stock) Is 750 rpm (s-afc)? If It Is, than you'll be the first to have matching tachs. I'll be Installing mine soon and am Intimadated to have a contrast with the rpms.
I'll post my results.
Old Sep 21, 2002 | 10:11 AM
SPDST3R's Avatar
yup, it's 99% sync all the way up. Now i can really tell the idle is not steady because the numbers are going up and down. But I noticed that the idle is smoother now. My idles used to move bet 700 and 900 and now it stays at 750'ish.
Old Sep 21, 2002 | 12:02 PM
Aaron Cake's Avatar
Engine, Not Motor
I believe the S-AFC and tach get their RPM signals from different points...The S-AFC gets it from the CAS, the tach from the trailing coil. But I could be wrong (probably am).
whinin
Mar 30, 2019 07:53 PM
Snook
14
Oct 1, 2015 10:56 AM
apooch
Sep 4, 2015 10:27 AM
tiger18
Sep 3, 2015 08:27 PM
