Do FC's have abs? and is there a different intake between models?
Old Sep 20, 2002 | 04:57 PM
BrainFood's Avatar
I was wondering if any of the models come with ABS and also if there is a different intake manifold between the n/a's and tII's?
Old Sep 20, 2002 | 05:01 PM
OC_'s Avatar
OC_
I'm bastardizing my car!
Yes and yes.
in my owners manual, it says abs was an option for my s5.
the intake manifold is different because the turbo engine is a 4 port engine and the na has 6 ports
Old Sep 20, 2002 | 05:15 PM
AreExSeven's Avatar
Huh?
I believe all S5's (89-91) came with ABS. Easily removable by the way
Old Sep 20, 2002 | 05:20 PM
FC Drifter's Avatar
Damaged Little F*cker
only a few 89+ FCs had ABS. it was a rare option that i personaly havent seen much of(only one car so equiped). ive heard good and bad things about its performance but i do know that if a T2 has ABS, then it makes it really hard to do work on that side of the engine. its right above the turbo. umm, i dont think it would be that easy to remove. it would require new brake hard lines and a whole mess of new stuff to be installed. i dunno though, never had much experience with it.
Old Sep 20, 2002 | 05:25 PM
AreExSeven's Avatar
Huh?
All it takes to remove it is a Jyard trip
I got mine for like $50, and it'll take me maybe 2 hours at the most.
j9fd3s's Avatar
Community Builder
abs was first offered in 87 on the gxl and turbo2 only.
in 89 it was standard on the turbo, optional on everything else
mike
Old Sep 20, 2002 | 05:53 PM
Silkworm's Avatar
Has been.. hangin' around
Edit: Nevermind, you did it the right way. Although I ague, that's not exactly what most people call easy.
PaulC
Old Sep 20, 2002 | 06:11 PM
AreExSeven's Avatar
Huh?
Ya, well with the engine out, its easily accessable
EDIT - What I meant by easily removable was: It is not something that is hard enough to do that it should sway your decision to buy the car
Old Sep 20, 2002 | 06:34 PM
I wish I was driving!
The ABS on RX-7's sucks ***. About half of the ABS pumps leak brake fluid, a new pump is over $2000, and AFAWK, the pumps are not rebuildable.
I removed my ABS pump before it started leaking.
Old Sep 20, 2002 | 06:36 PM
I dont have ABS on my S5 Vert.
rgordon1979
40
Mar 15, 2022 12:04 PM
FD3S_wanted
Sep 22, 2015 06:18 PM
Devon300zx
15
Sep 16, 2015 06:57 AM
kkev.7788
Sep 2, 2015 01:32 PM
