How does porting IM work?
Old Sep 17, 2002 | 12:44 PM
Rxmfn7's Avatar
Do a barrel roll!
When I am porting my Intake manifold I get kinda confused as to how it is going to flow more air?? I mean, I can open up the ends of the Upper and lower manifolds slightly, but the center of the runners is still going to be the same diameter, so its still gonna bottleneck down to that point and restrict the air flow, wont it? Wouldnt it kinda be like an exhaust system, if you have a 3' exhaust but goes to a 2' midpipe then back to a 3' catback, the flow would still be restricted by the midpipe, right? Im just kinda confused as to how its gonna flow alot more, just by opening up the ends. Could someone explain how this works?
Old Sep 17, 2002 | 12:51 PM
really the best you can do is to matchport the interfaces btwn the lim and uim, and the lim and intake ports. you're exactly right about the rest of the runner length being the bottleneck so there's not point in making the ends bigger. it's prolly not even worth it to port the im if it's not a high hp turbocharged application, you can't even feel the difference imo.
Old Sep 17, 2002 | 01:11 PM
I wish I was driving!
is get it extrude honed.
Old Sep 17, 2002 | 01:15 PM
Re: How does porting IM work?
A restriction is a restriction. Removing restrictions makes power.
Example: Removing the cats (restriction), but keeping the stock cat-back (restrction) will add power.
Example: Removing the stock air box (restriction) but keeping the AFM (restrction) will add power.
Gasket matching your intake is about the best you can do at home. Yes, other restrictions will still exist in the intake, but removing some of the restriction will add power.
Old Sep 17, 2002 | 03:13 PM
Rxmfn7's Avatar
Do a barrel roll!
Yea I suppose that any restiction removed ia a +, but it just seems like there is a bottleneck before and after the ends of the runners, so there isnt really going to be any more air getting in. In the case of the airbox, that is a flow restriction that is the first thing that the air goes into, so there can be more air without it. As for the cats, they themselves are an actual flow restriction, not just smaller piping, so its understandable why you get gains from gutting them. I know that it does help flow, just having trouble understanding why....
Old Sep 17, 2002 | 03:45 PM
Samps's Avatar
this is why!
Old Sep 17, 2002 | 03:49 PM
adamlewis's Avatar
Back from teh deadly!
best picture ever samps
Old Sep 17, 2002 | 03:51 PM
Samps's Avatar
The runners need to flow as smooth as possible. And where the manifolds meet there is a less than desireable connection. Porting allows the transition from the upper to lower manifold with less turbulance.
Old Sep 17, 2002 | 03:52 PM
Samps's Avatar
thank you, thank you very much. I spent all day on that and was hoping someone would appreciate it. hehehe
Old Sep 17, 2002 | 04:18 PM
silverrotor's Avatar
It got my attention.
Old Sep 18, 2002 | 11:30 PM
Scott 89t2's Avatar
SOLD THE RX-7!
Old Sep 19, 2002 | 12:14 AM
Scott 89t2's Avatar
SOLD THE RX-7!
bump, I'm waiting for a comment LMAO
Old Sep 19, 2002 | 12:26 AM
importboi22's Avatar
Hks Ownz Me (
no no you want to have the BAD picture with the airpump cuz when you get all the swirls from not port matching it helps the airfuel mixture therefor getting a full burn effect of all the gas... you get what im saying rite..... screw porting man the airpump makes MAD POWER!!!
Old Sep 19, 2002 | 09:05 AM
Rxmfn7's Avatar
Do a barrel roll!
Old Sep 19, 2002 | 12:00 PM
Samps's Avatar
If I were to zoom out on my original graphic; you would see the small computer fan that was installed inside the air-filter. It moves upwards of 50cfm and made a huge difference in parking-lot power. But I'll save that mod for later. hehehe
Old Sep 19, 2002 | 12:03 PM
RacerXtreme7's Avatar
NASA geek
AIRPUMP!!
hotshot2014
Jul 18, 2017 02:30 PM
wallyrx7
Rotary Car Performance
Aug 20, 2015 05:55 PM
Engine stand ready
Aug 14, 2015 10:26 PM
