Expert HELP PLEASE!
Old Sep 17, 2002 | 11:09 AM
Cool Expert HELP PLEASE!
I need to re-attach a wire!
Up against the firewall under the hood on the passenger side...you can see a VIN number...right below the VIN# there's a bolt/screw with a wire...where should the wire actual be attached too on the engine?
1988 none turbo RX7
Old Sep 17, 2002 | 11:10 AM
hIGGI's Avatar
ground wire to block or tranny
Old Sep 17, 2002 | 11:29 AM
hugues's Avatar
Why am I here ?
I think it connects to the block somewhere underneath the intake (more towards the driver side).
Hugues -
Old Sep 17, 2002 | 11:31 AM
THE WIRE ISN'T THAT LONG!!!
please check you rx7...and help me out
Old Sep 17, 2002 | 11:41 AM
hugues's Avatar
Why am I here ?
ok ,I have just looked.
It's going right on top of where tranny connects to engine. Can't miss it. there's a clippy thing to connect it.
Hugues -
Old Sep 17, 2002 | 11:50 AM
you wouldn't happen to have a picture????
do you think it makes a difference if I have a 5 speed?
Old Sep 17, 2002 | 11:58 AM
Turbo II FC's Avatar
Total Balance is Key
Hey dlbrown, what kind of problems did you experience without this ground connected? Im just curious because mine was disconnected too. I know that the purpose of it is to ground the engine and tranny but what happens if its not grounded? Any replies would be helpful.
Old Sep 17, 2002 | 12:05 PM
none that I know!
I don't think it has anything to do with my converters dying, or my spark plugs dying......I just recently noticed it yesterday while trying to to take off my 02 sensor!
Old Sep 17, 2002 | 12:11 PM
Koo. Well ive been having trouble with my turbo II about not wanting to go over 3800 at all. It just really bogs. So I figure it has something to do with my secondaries. But I saw this and thought, hmmm, ill plug this in and see what happens. Thanks though.
Old Sep 17, 2002 | 12:12 PM
Rotorific's Avatar
I dont know a damn thing
That wire is a GROUND wire there is no volage in the wire... the grounds are there to show how shitty the cars grounding system is they are everywhere. Dont take it off cause that is one of the main ones and the leading cause of the 3800rpm hesitation
Old Sep 17, 2002 | 12:15 PM
Rotorific's Avatar
as for your plugs and cats that is an air fuel problem or afm problem are your cats old cause you could have clogged cats or your o2 sensor could be off and it would jack up the readings is your car running rich maybe richlean screw near the boost sensor has been tampered
Old Sep 17, 2002 | 12:19 PM
The 02 senser is on tight, hell I couldn't get it off...I wanna replace it....where's the screw to ajust the richness of the gas......and where should I attach the wire to....it's black???
Daua118
SE RX-7 Forum
Dec 5, 2021 04:15 PM
purple82
West RX-7 Forum
11
Oct 2, 2015 07:23 AM
carid
Vendor Classifieds
Sep 10, 2015 09:24 AM
