not enough boost, non-sequentially
Old Sep 14, 2002 | 12:34 AM
White94RX's Avatar
BMW Tech
Hey, I just got an HKS downpipe put on my '94 Touring. The turbos are set up nonsequentially. I may have done it wrong though. I opened up the pre-spool door, and the turbo control door. I plugged the hoses on the charge control, and I spliced the other BOV into the first one. I didn't mess with the wastegate control solenoids. Does it matter if I unplug those hoses and stop them up, or are that step only to prevent the turbo control and prespool arms from moving?
Before the downpipe, I was getting 5 psi, with a good bit of lag. With the downpipe, there's still some lag (a little less), but I'm only getting 6 psi. Do I have a leak, or what? How can I get 10 psi?
Any comments are appreciated.
Old Sep 14, 2002 | 01:02 AM
Ralgh's Avatar
If you haven't done a search go ahead and do one. There are tons of threads on non sequential. There might be some good info there. My brother is going to go non sequential and he had found lots of good stuff.
Old Sep 14, 2002 | 02:12 AM
spooledUP7's Avatar
There and back again
Do you still have the pill in the wastegate line? You should try a smaller pill, or use a boost controller.
Old Sep 14, 2002 | 02:33 AM
neevosh's Avatar
The Dude Abides
Is it 6psi throughout the rev range or just above 4500RPM's? Check all your solenoids and lines for leaks. I still had a boost leak after going non-sequential and fixed it by capping off all the solenoid lines I no longer needed.
Old Sep 14, 2002 | 03:10 AM
White94RX's Avatar
BMW Tech
The pills are still there. And it's 6 psi throughout the RPM's.
Shainiac
Jul 17, 2019 02:20 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
Bauer778
Nov 4, 2015 04:42 PM
High_Carb_Diet
Power FC Forum
Sep 5, 2015 09:07 AM
