Question for anyone running Mikuni's on a 12a
Old Sep 12, 2002 | 01:08 PM
CrazyJoe12a's Avatar
Looking at getting a set of either 42 or 44mm Mikuni's and was wondering what intake manifold could be used with them.
Thanks,
Joe
Old Sep 12, 2002 | 03:14 PM
DriveFast7's Avatar
Blood, Sweat and Rotors
http://piercemanifold.com/
And even the 44mm mikuni is too small. Start with a 48mm DCOE or Dellorto.
-bp-
Old Sep 12, 2002 | 05:28 PM
I'm pretty sure running 2 44mm Mikuni's would be enough to feed a stock port 12a.
So would a Weber manifold work?
Old Sep 12, 2002 | 06:27 PM
mperformance's Avatar
A 44PHH is ok...I had one on a streetported...
all about tuning.
Old Sep 12, 2002 | 10:00 PM
WackyRotary's Avatar
standard combustion
I bought the 44PHH mikuni setup years ago. Made the stock engine much more fun. However, it was too small for a bridgeport, so I took it off and inserted a 50DCO weber and matched the diameter of the tubes so the bore was the same were the carb mates.
Mikuni 44PHH is good for stock or mildport 12a forsure. I loved that carb for the added performance and not really any loss in MPG too. Rev'd much more smoothly then the Nikki crap and simple to adjust and idle very smooth.
Old Sep 13, 2002 | 05:18 PM
So what intake manifold did you use?
Old Sep 13, 2002 | 09:15 PM
standard combustion
THe common wrap around type that came with it.
Old Sep 14, 2002 | 07:38 PM
So is there a specific Mikuni manifold for the 12a, or can any of the "wrap around" style work?
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
rx7brandon
Aug 16, 2015 10:55 AM
Professorpeanutrx7
Aug 15, 2015 01:38 PM
