Spark Plugs/Converters
Old Sep 11, 2002 | 06:35 PM
Angry Spark Plugs/Converters
Two part question,
Every 3 months I need to replace my spark plugs, and every 6 months I've been replacing my converters...what's causing this problem...and what can I do to reslove it?
1988 NONE turbo RX7
Old Sep 11, 2002 | 06:39 PM
biorotary's Avatar
what's the problem??
Old Sep 11, 2002 | 06:44 PM
Aaron Cake's Avatar
Engine, Not Motor
You're running rich. Have all injectors professinally cleaned, change the temp sensor on the thermostat housing, change your O2 sensor, and adjust the idle mixture.
There may be other causes, but these are the most common. Also, test your ACV.
Old Sep 11, 2002 | 09:29 PM
Question
uMMMMMMM, Question,
What is a ACV?
AND HOW DO YOU adjust the idel mixture?....or is it called a different name?
Old Sep 17, 2002 | 08:01 PM
DavidDeco's Avatar
I have more fun than you.
Talking
Your avatar rules. Can you send me a larger enhancement
Old Sep 17, 2002 | 08:05 PM
Aaron Cake's Avatar
Engine, Not Motor
ACV=Air Control Valve....
I think you should get a Haynes manual, or at least figure out how to use the search.
Prediict
32
Nov 18, 2015 08:41 AM
Aramir
Oct 18, 2015 02:39 AM
tctwaites
Sep 22, 2015 08:48 PM
