No filter on the MAP sensor hose, bad?
Old Sep 10, 2002 | 09:31 PM
Swamp RX-7's Avatar
Question No filter on the MAP sensor hose, bad?
I've noticed that I don't have the gas filter that goes from the intake manifold to the MAP sensor. Is this a bad thing?
Old Sep 10, 2002 | 09:57 PM
JONSKI's Avatar
5yr member, joined 2001
When I did my hose job, I noticed mine was backwards. I don't think it damaged anything.
Old Sep 10, 2002 | 11:15 PM
paw140's Avatar
Just buy one and throw it on. Should be fine.
Old Sep 10, 2002 | 11:16 PM
johnchabin's Avatar
I tried to buy one from the dealer. They couldn't find it on the fische.
Old Sep 11, 2002 | 08:38 AM
blackscorpio's Avatar
#1 F0RUM TROLL
Dealers = retartds
Old Sep 11, 2002 | 10:23 AM
Mahjik's Avatar
Mr. Links
Actually, there are quite a few parts that aren't on the diagrams/fische.. The last one I ran into were the studs on the throttle body. They list the ones on the UIM, but not the throttle body. I live in Ford country, so no automotive shop had anything that would work.
The parts guy at Mazda found something close that worked just fine thank goodness.
Old Sep 11, 2002 | 10:42 AM
tfhuth's Avatar
Originally posted by blackscorpio
Dealers = retartds
Hehehe
Old Sep 11, 2002 | 03:42 PM
RonKMiller's Avatar
Blow up or win
Re: No filter on the MAP sensor hose, bad?
Yes - it's there to protect your $400 sensor.
Mazduh will get you for about $25 for the little bastard, but put in on.
Old Sep 11, 2002 | 04:58 PM
DK's Avatar
DK
40k worth of fail
I have a fuel line filter from a lawnmower on mine, I think. It was like $3.
Old Sep 11, 2002 | 06:03 PM
JONSKI's Avatar
Not that kind of gas. Gas like the phase of matter. It keeps crap from getting into your MAP sensor. It's the thing that I'm holding, and that's the direction it's supposed to go.
Old Sep 11, 2002 | 06:54 PM
DK's Avatar
DK
40k worth of fail
Yes this I know. I'm not a moron. However, they are both simple screens that will serve the same purpose. When my car was stripped, the original disappeared ... along with most everything else.
Old Sep 11, 2002 | 07:37 PM
peejay's Avatar
Old [Sch|F]ool
you're sure it's not to prevent any liquid fuel/oil that might be in the intake from getting to the MAP?
'cos if you think about it, there isn't really any airflow to/from the MAP, and any air that is there would be/should be filtered already since it gets its pressure/vacuum from the intake manifold.
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
