-SE vs S4 differences
Old Sep 7, 2002 | 06:42 PM
Project84's Avatar
Open up! Search Warrant!
Ok, I been asking some questions in the 2nd Gen forum cause I got this N/A engine (short block) out of a '87 and was taking it apart to replace the water seals and blah blah blah..... Anyway, its a 6 port N/A, and I noticed that the 4 oil injectors on my engine are located on the block itself. 1 at each rotor housing, and 2 on the center plate. All the 2nd Gen guys say they have 1 on each rotor housing and 2 in the lower manifold. one guy said I had a 84-85 SE short block. I heard that the SE's were all 4 ports. I guess it could have been a rebuild, but the owner thought it was the original engine. Can any of you SE drivers tell me what some of the physical differences are between a SE and S4?
Old Sep 7, 2002 | 07:01 PM
diabolical1's Avatar
the water seal locations ... SE's are in the rotor housings, the 86+ engines have the seals in the side housings.
Old Sep 7, 2002 | 07:04 PM
Re: -SE vs S4 differences
SE's are all 6-port!
Old Sep 7, 2002 | 07:12 PM
Project84's Avatar
Ok, I got it backwards then.
Old Sep 7, 2002 | 08:05 PM
Project84's Avatar
What about the oil injector location? I have 2 87 N/As and both have 2 oil injectors in the center plate.
Old Sep 7, 2002 | 08:14 PM
do you have a picture of what you're talking about?
Old Sep 7, 2002 | 09:44 PM
Project84's Avatar
Here are some of the pics of the oil injectors in the center plates and rotor housings.
This one is from an '87. I circled the holes where the oil injector are in my other engine.
Old Sep 7, 2002 | 09:49 PM
Project84's Avatar
Bump
Old Sep 7, 2002 | 09:53 PM
Project84's Avatar
This is the rear rotor housing that is removed from the short block. Again, I circled the oil injector
Old Sep 7, 2002 | 09:59 PM
Directfreak's Avatar
I am a Jeeper Now.
This is the oil injectors on my partially disassembled short block. The one is in the front rotor housing, and there are 2 in the center plate. You can also see the clear yellowish lines going to the OMP.
This is a 2nd gen shortblock? It has a CAS, for one thing. Is the answer your where asking? Or was it something else.?
If you need more info, I have my old shortblock in the garage and could check for you.
Old Sep 7, 2002 | 10:04 PM
Project84's Avatar
I was told that this is a 84-85 SE motor because the center plate had the injectors and not the lower manifold like in a S4. Did SE's have a dizzy cause mine has the CAS, as you can see on the front of the block.
Old Sep 7, 2002 | 10:15 PM
I am a Jeeper Now.
All Fuel Injected 13B's have Fuel Injector Bungs on the center plate from 84 on. Even my 95 Cosmo engine has them. SE's did have a Dizzy, and 86+ engines have a CAS.
Old Sep 7, 2002 | 10:16 PM
Project84's Avatar
damn it! Why can't I delete this?
Old Sep 7, 2002 | 10:17 PM
Project84's Avatar
Here is the 87 center plate injectors on the short block. It has the lines hooked up to the OMP and had the vaccuum lines on the top, but they are removed. Also, it has the CAS.
Sorry I delete the first pic, it was an accident.
Old Sep 7, 2002 | 10:36 PM
the picture that you called center plate.jpg = the fuel injector holes
housing oil injector.jpg = oil injection on the rotor housing
oil injectors.jpg is sort of unclear, but it seems to be another picture of the fuel injector holes.
there are only 4 oil inection holes, 1 on each rotor housing and 2 are on the lower intake manifold, that goes for the the SE and the Gen II motors. the two holes in the intermediate housing are for the primary fuel injectors.
Old Sep 7, 2002 | 10:50 PM
Project84's Avatar
Ok, so if I want to run a carb, I have to plug those holes in the center plate right? I found the pic of the fuel system in my FSM and circled the primary injector, but the block I got had the OMP lines running to those fuel injectors. I guess thats a goof on the last owners part, who knows. All the injectors look alike, so can I use the two on the center plate as oil injectors in the lower manifold?
Old Sep 7, 2002 | 10:58 PM
yeah, if you want to run a carb, they have to be plugged. if you run a downdraft system, you can just leave the injection block (with the injectors in place) and not worry about it. however, if you run a sidedraft that sucks air from the left side of the car, like the Dell'Orto, the injector block will not clear the carbie. on that issue, i can give you 2 options ...
the proper way: RB sells a fuel injection plug kit (about $40)
the ghetto way: stick two dimes in the holes to lay flat, then put some epoxy in over them.
guess which one i did?
Old Sep 7, 2002 | 11:06 PM
Project84's Avatar
Ha ha! I rather spend $0.20 instead of $40 any day!
Thanks for all the help. I drove a 1st gen for a long time, and never took apart a rotary engine. I have a haynes manual and a FSM. I figure that i'll take my time, ask questions here, and I'll be all set.
Old Sep 7, 2002 | 11:16 PM
well, keep 'em coming ... as long as i know the answer, i'll help you out, and i'm sure the same thing goes for the other guys in this forum, too.
Shainiac
Jul 17, 2019 02:20 PM
Joe428
Sep 29, 2015 06:58 PM
Ian_D
Sep 6, 2015 10:38 PM
