What would happen if my EGR was shot?
Old Sep 6, 2002 | 01:37 AM
Toddzilla's Avatar
Would it cause the car to idle poorly and fail emissions?
Old Sep 6, 2002 | 02:18 AM
duboisr's Avatar
if the valve leaks the idle would be poor . If the electric part is bad the computer will give a code. A bad valve = bad idle = fail smog test
Old Sep 6, 2002 | 10:40 AM
Street King's Avatar
*** Bless Texas!
If I'am correct, then the EGR is only used in certian RPM ranges say i.e.; from 2k-3k rpm's. The RPM range is very short. If you have a 93' FD, then you can just take it out and block it off, no harm. If you have a 94'-95' FD then you need to do the same as a 93' FD, then you need to use a resistor to trick the ECU into thinking it's working correctly. There are sites with the How-To. If it's a 93 it will not throw an ECU code.
Old Sep 6, 2002 | 10:47 AM
Jim Calandrella's Avatar
The Ricer Eliminator
Is that 93 thing true? I have a 93 touring, and just pulled code 16(EGR valve) last night. It's been an ongoing saga. I guess I just have to replace it. As said before, you can take it off, and put a resistor there, but you have to replace the resistors from time to time. I'm too lazy to do that. I'd rather have everything straight forward.
As stated above, the symptoms are bad idle, and running rich.
Good luck
Jim
Old Sep 6, 2002 | 10:52 AM
JONSKI's Avatar
5yr member, joined 2001
The california '93s will throw an error code if ERG is removed with no resistor.
Old Sep 6, 2002 | 11:45 AM
*** Bless Texas!
AHHHH the California cars, I always forget about them. Yes if you're in California then all FD's will need a resistor to by pass the EGR. If you are not in Cali. and it is a '93 then just pull it off and then plug the lines. If it's a '94-'95 FD(including Non-Cali and Cali FD's) then you will need a resistor. Juts search I believe it will show you step by step.
Old Sep 6, 2002 | 01:13 PM
I guess I have a Cali car. What the hell am I doing with a Cali car in Boston? I guess i'm going to do some research as to where my car came from.
Very interesting..............
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
Prediict
32
Nov 18, 2015 08:41 AM
musker
Oct 1, 2015 05:58 PM
