6 port... wha???
Old Sep 3, 2002 | 03:04 AM
ioTus's Avatar
'84 5-letter
6 port... wha???
I can see 4 port, intake and exhaust, one set per rotor. SIX port? How does this work?
Also, which does the GSL-SE have?
Thanks, Geoff
Old Sep 3, 2002 | 04:52 AM
REVHED's Avatar
Hunting Skylines
Firstly, a 4-port engine has 4 intake ports... a primary and secondary for each rotor.
A 6-port engine has an auxiliary intake port above each of the secondaries which only opens under increased load. This is done to try and give the engine better performance over a wider rpm range. SE's came with a 6-port.
Old Sep 3, 2002 | 10:56 AM
ioTus's Avatar
'84 5-letter
Know of any pics where i could see this on the housing? I thought it was the single wedge shaped intake port, and the round exhaust port... (now i feel reel dumb hehe)
Old Sep 3, 2002 | 11:25 AM
Manntis's Avatar
add to cart
It's not really a port in the housing, it's in the Dynamic Effect Chamber in the intake manifold.
Primary air is inducted through it's own tuned passage and is split between front and reat rotors - this air is tuned for low RPM. Secondary air enters in through two additional ports, one for the front rotor, one for the rear, when it's required at high RPM. These are opened by exhaust back pressure.
This is considered three stage porting, with the additional intake ports positioned before the final induction. So even though the housing still has just the intake and exhaust ports, it's a 6 port engine.
Old Sep 3, 2002 | 11:28 AM
Defprun's Avatar
Punk Ass Bitch
Superman has "wooshed" in and saved the day, lol
Old Sep 3, 2002 | 11:44 AM
abeomid's Avatar
ok here are some pictures,
This first one is the 6port manifold, As you can see the intake ports on the both sides each have two holes:
Now this next one is a 4port manifold. Now the side ports are one huge port instead of two smaller ones.
This is identical on engine as well.
All the 13B's prior to GSL-SE are 4-port.
All the 12A'a are 4-port as well (well I know the RX-7's are).
GSL-SE and all the 2nd gen 13B N/A's are 6-port.
All the 13BT and 13B-REW are 4-ports as well.
Old Sep 3, 2002 | 04:38 PM
REVHED's Avatar
Hunting Skylines
You really have no idea what your talking about...
Here you can see the auxiliary port above the secondary port as clear as day.
Old Sep 3, 2002 | 04:42 PM
Manntis's Avatar
add to cart
...cursed photo evidence...
Old Sep 3, 2002 | 04:43 PM
REVHED's Avatar
Hunting Skylines
Looking at the end plate from the manifold side you can see the valve in the top runner that opens up to allow air/fuel into the auxiliary port.
Old Sep 3, 2002 | 04:45 PM
Manntis's Avatar
add to cart
Alright, I was incorrect. I was paraphrasing from something written by Csaba Csere about the 13B.
Serves me right for being lazy
Old Sep 3, 2002 | 04:49 PM
REVHED's Avatar
Hunting Skylines
Yeah, I didn't mean to be harsh... it's just that I get annoyed with mis-information (god knows there's enough of that on this site already).
Old Sep 3, 2002 | 04:51 PM
Manntis's Avatar
add to cart
Like "oh, you forgot to put anti-squeal grease on your brakepads? Just grease your rotors and it'll get into the pad once the wheel turns"...
that was among my favorites
Old Sep 3, 2002 | 05:59 PM
S2-13BT's Avatar
, someone actually said that. I sincerely hope the advice was not taken.
Old Sep 3, 2002 | 10:41 PM
RotorMotorDriver's Avatar
Seven Is Coming
Kinda like a Vtec engine if you know Hondas .
~T.J.
Old Sep 21, 2002 | 07:17 PM
Guackman's Avatar
I was just reading this thread about the auxiliary ports on the GSL-SE 13B and thought I would ask a question since I recently purchased one and am just getting familiar with it.
I noticed that the backpressure hose from the exhaust is not connected to the tube on the auxiliary port actuator valve. The small hose from the valve is blocked with a screw. I guess whoever replaced the exhaust must have not attached it.
Does this mean my auxiliary ports are not opening? The car seems to have great power but maybe the top end isn't what it should be. I don't know because I never drove it with the hose attached.
I plan on putting low pressure into this hose tomorrow to test the actuator valves to see that they work.
The funny thing is I did notice a place on the exhaust just after the rear catalytic converter to attach a sensor or something. It was just open so I plugged it with a cover. I guess I should get the proper attachment for this to connect the hose to the auxiliary port actuator valve?
I plan on ordering a replacement pipe to fo where all the cats are from Racing Beat. They say they have a place to attach this hose on their pipe. I also plan on getting the power pulse main muffler from the. What do you guys think?
Thanks Again for any input.
Greg
Montreal, Quebec
1985 GSL-SE no mods ..... yet!
Old Sep 21, 2002 | 08:20 PM
Stripgear's Avatar
Yes, that's what it means!
Old Sep 22, 2002 | 03:58 AM
Powerslave's Avatar
My 12A's farked
Should I get a 4 port or 6 port 13B? I just want a simple upgrade. Is one easier to install than the other? Is the 6 port more economical and powerful? hmmmmz
Old Sep 22, 2002 | 01:49 PM
Manntis's Avatar
add to cart
The 6 port 13B is the one that actually came in the GSL-SE RX-7. You can get a parts car and swap over much of the engine bay contents.
The 4 ports came in other cars, so might require more custom fabrication to mount into your vehicle (I'm talking engine mounts, auxillary systems, etc.)
Old Sep 22, 2002 | 11:46 PM
Project84's Avatar
Open up! Search Warrant!
Csaba Csere
'nough said.
Old Sep 23, 2002 | 08:38 AM
Powerslave's Avatar
Considering I waited to get the best Aussie 1st Gen, Id already own a GSL-SE if i was in the USA...the 4 port is easier to get here and more familiar for mechanics to work with a carby.
Old Sep 23, 2002 | 02:09 PM
Manntis's Avatar
add to cart
CAn't argue with that. The Canadian GSL-SE comes with snazzy headlight washers though...
Old Sep 23, 2002 | 03:45 PM
REVHED's Avatar
Hunting Skylines
So do all Australian delivered Series 2's and 3's...
Sobr609
Dec 30, 2006 10:59 PM
stillmello
39
Jun 10, 2004 09:25 AM
stillmello
Interior / Exterior / Audio
20
Jun 9, 2004 08:23 PM
subgraphic
14
Dec 31, 2002 01:48 PM
stillmello
Rotary Car Performance
Nov 19, 2002 09:51 PM
